Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
1442
Beginner
ASA5515X-IPS management 0/0 to LAN
I've recently setup two ASA5515X in A/S each with IDS. When I had them in the lab I was able to access the IPS's via IME but now that it's at the datacenter it's not working (of course). I've got the IPS configured with an IP on our LAN and the ASA's Management0/0 interface configured as:
interface Management0/0
no nameif
security-level 100
no ip address
management-only
The Management0/0 interface is plugged into a switchport on our LAN VLAN. From the ASA it's seeing the IPS as Up and I've verified the IPS network settings. Any ideas? Did I forget something? TIA!
1 ACCEPTED SOLUTION
Highlighted
Okay. Let us know any update.
The person in charge of the case will have access to the box so he or she will be able to run some captures.
It is weird that you do not have the MAC address of the IPS module on the switch, I would check the layer 2 topology first.
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
15 REPLIES 15
Highlighted
So you cannot access the IPS from the inside network right?, what is the Ip address you have provided to the IPS?, what is the default gateway ip of the IPS? What is the internal subnet network?
Julio
Julio Carvajal
Highlighted
Beginner
Re: ASA5515X-IPS management 0/0 to LAN
That is correct, I'm unable to access the IPS from the LAN subnet of 192.168.173.0/24.
The IPS is 192.168.173.221, default gateway is the core switch at 192.168.173.254.
Highlighted
Can you change the default-gateway to the ASA internal Ip address??
Julio Carvajal
Highlighted
Beginner
I changed the default gateway on the IPS to the IP of the ASA (192.168.173.162), but still no connectivity. I have also verifiied the IPS ACL and that it does include the 192.168.173.0/24 subnet.
Highlighted
Can you add :
same-security-traffic permit intra-interface
Also do you see any logs from the ASA?
Julio Carvajal
Highlighted
Beginner
I already had "same-security-traffic permit intra-interface" and "same-security-traffic permit inter-interface" in the ASA, double checked to make sure. Turned on debug logging and then ran a continuous ping from a host on the LAN to 192.168.173.221 and checked the logs for any traffic going to/from 192.168.173.221 but not seeing anything in the debug logs.
Highlighted
Can you share the topology you have?
Should be like this:
So managment traffic from inside to IPS never reaches the ASA!
Remember to rate all of the helpful posts, that is as important as a thanks ( if you need assistance on how to rate a post, let me know, I will be more than glad to help)
Julio Carvajal
Highlighted
Beginner
Your topology is correct. It's:
hosts --> 3750 stack--> ASA LAN interface
hosts --> 3750 stack--> ASA Management 0/0
Very straight forward. I had opened a TAC case to figure how to get this working and basically I just had to remove any IP from the Management 0/0 interface and then plug it into a switchport in the LAN VLAN. I had it working when it was on my desk, but for some reason it's not working now once in place at the datacenter. How can I find that MAC address of the IPS? I can then make sure the Mangement 0/0 interface is plugged into the correct VLAN and that a cable wasnt plugged into the wrong interface.
Highlighted
Based on what you have said so far, looks like there something outside the ASA or IPS causing the issue ( Switch problem)
Please check the vlan and port assingment as now everything is properly.
On the IPS run a show interface command and you will get the MAC add.
Julio Carvajal
Highlighted
Beginner
When I run "show interfaces" I only get statistical information, nothing L2:
Interface Statistics
   Total Packets Received = 0
   Total Bytes Received = 0
   Missed Packet Percentage = 0
MAC statistics from interface Management0/0
   Interface function = Command-control interface
   Description =
   Media Type = TX
   Default Vlan = 0
   Link Status = Up
   Link Speed = Auto_1000
   Link Duplex = Auto_Full
   Total Multicast Packets Received = 0
   Total Receive Errors = 0
   Total Receive FIFO Overruns = 0
   Total Packets Transmitted = 171
   Total Bytes Transmitted = 7182
   Total Transmit Errors = 0
   Total Transmit FIFO Overruns = 0
MAC statistics from interface PortChannel0/0
   Interface function = Sensing interface
   Description = Backplane
   Media Type = backplane
   Default Vlan = 0
   InlineMode = Unpaired
   Pair Status = N/A
   Hardware Bypass Capable = No
   Hardware Bypass Paired = N/A
   Link Status = Up
   Admin Enabled Status = Enabled
   Link Speed = N/A
   Link Duplex = N/A
   Total Packets Received = 988315
   Total Bytes Received = 77088570
   Total Packets Transmitted = 988315
   Total Bytes Transmitted = 77088570
Highlighted
Beginner
Believe I found the MAC. If I run "show module IPS" from the ASA I get a MAC address range.
Highlighted
Beginner
I checked the 3750 stack for both of the IPS's in the A/S ASA setup and neither MAC is showing up, but the management interfaces are showing as up/up. Also, neither one of the Management 0/0 MAC's is showing up in the 3750's either.
Highlighted
Beginner
Also tried a "sw-module module ips reload" but not joy. Will open a TAC case tomorrow.
Highlighted
Julio
Julio Carvajal
Content for Community-Ad
FusionCharts will render here
