Ask the Expert: Cisco Intrusion Prevention System (IPS)
ciscomoderator
Community Manager
Community Manager
Read the bioWith Robert Albach
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn and ask questions about security best practices and management for the Cisco Intrusion Prevention System (IPS) with Robert Albach. The Cisco Intrusion Prevention System is a context aware threat prevention system for your networked environments. The module unobtrusively detects and prevents problematic traffic from reaching its target; uses contextual inputs to determine the proper level of response; and tightly integrates with the ASA firewall for greater network security.
Robert Albach is a product manager in the Security Business Unit at Cisco, responsible  for intrusion prevention offerings. Before joining Cisco in 2010 he held product management positions for intrusion prevention offerings at Hewlett-Packard/TippingPoint. He has more than 15 years of experience with systems management and security product offerings and has presented at the RSA trade show and other security venues.
Remember to use the rating system to let Robert know if you have received an adequate response.
Robert might not be able to answer each question due to the volume expected during this event. Remember that you can continue the conversation on the  Security sub-community discussion forum shortly after the event. This event lasts through through September 7, 2012. Visit this forum often to view responses to your questions and the questions of other community members.
78 Replies 78
Robert I apprecieate you providing us the SNMP OID for load on the IPS modules for ASA firewalls.  I was looking for clarification.  Is the OID you've mentioned in the support forum
1.3.6.1.4.1.9.9.383.1.4.30.0.
provide me the same output as when I look at load in IME for that device?  Say IME says 5% load for that IPS, the OID you provided is it the same info?
Further to this, if we have IPS's that are not on 7.1 and can't support this, what are our other options for reporing load issues back to us?  Can we send TRAP alerts when the load reaches a certain level somehow?  If so how do we do that as its not clear in documentation.
Hi Robert
Ok - I opened also a TAC case on it yesterday so we'll see - thanks
/ti
Hi Robert,
We have IPS 4260 device with 7.0(8)E4 version software. The IPS software is Linux-based and it have embeded OpenSSH 3.7.1p2. This version of OpenSSH have some vulnerabilities. So my question: Have Cisco a plan to switch the new version OpenSSH (e.g. 4.4)?
obryadinrv
Hi, Robert.
We have Cisco IPS4255 7.1(7)E4 in promiscouse mode (connected to switch SPAN port).
SPAN port monitors traffic from one trunk port with one vlan allowed.
There are a lot of fiers of TCP Segment Overwrite signature (ID:1300/0).
After invertigation I think, that the df-bit set is the reason of this problem.
We have this topology:
host1(MTU1500) -> LAN (Switch) ->(IPS connected to switch SPAN port)-> local router (route map with DF-bit set) -> ipsec tunnel (with smaler MTU<1500) -> remote router (route map with DF-bit set) -> remote LAN-> host2(MTU1500).
After the host1 established tcp connection with host2 it sends first data segment, and the segment size is too big to go through ipsec-tunnel without fragmentation. A this moment IPS sees this first data segment.
Local router sends the icmp (need fragmentation with information of the next hop MTU) paket to the host1, and host1 resends the first data segment with less segment size to go through ipsec-tunnel without fragmentation. A this moment IPS sees the data segment (atleast first 256bytes) second time and TCP Segment Overwrite signature is fired.
I don't know yet how to solve this problem. My exp in IPS is not yet enough.
May be there is a method to filter out this alerts.
dheeraj_singh
Hi Robert,
We are haing ASA SSM 40 module NIPS at perimeter network. When I keep  the IPS in promiscuous mode then eveything is workign fine and when i had configured the same module in inline mode then i am not able to take putty or telnet of the internet router.
During the inline mode,  IPS is drooping our telnet and SSH traffic and also event is also not genrating the for the same.
We have tried to find the traffic event for router ip and as well as for my system ip. nothing is showing in event.
I used the command sh event from CLI and also checked from ASDM alsbut not getting any scusses.
NIPS IOS version is 7.1(4)E4.
Please help me for the troubleshooting for this issue.
Hi Dhreeraj,
if you are having cisco IME check real time log while doing ssh/telnet to your router.
check if there is any signature is hitting at that time.
Prashant
Hi Prashant,
Thanks for your resonse.
We are not having real time log anlysis server but when I am checking the IPS event logs, there is not showing any droped traffic for ssh or telnet from my system.
Even I have tried to bypass the traffic from the my ststem to internet router but no success.
Just want to confirm  that can i bypass the particular defined traffic in ASA SSM 40 IPS module.
Thanks...
HI Dheeraj,
That is a strange issue...
can you tell me how you try to bypass the traffic from your system to internet router ..
if possible can you post(mail) your ips Configuration .
one thing you can try event action overide ...you can create a rule to not block any traffic from your machine ..(i have not check it but you can try )
below is the link for event action override ...
http://www.cisco.com/en/US/docs/security/ips/7.0/configuration/guide/cli/cli_event_action_rules.html
Prashant
Thnaks Prashant for your support..
We found that there is problem with default sersor but other Internal IPS with default sersor working properly. We have deleted defaults virtual and created new virtual sensor (VS0).
Problem is resolved now.
Dheeraj
TM13
All we have ASA 5510 and IPS 4240 and our upload speed is very slow, and sometimes it is not allowing any traffic, i see Deny connection messages on ASA, and no logs on IPS, and just found https://supportforums.cisco.com/thread/228118
this section, we just updated latest signature still same, any idea about that Regex?
jmp780718
is possible to config an subscrat rule for all the signatures enables in IPS?
Thks
eddiedelcid
Hello Robert,
Is that possible to authenticate windows AD users with de IPS module on ASA 5585x?
Is necesary a CDA to do this like the configuration of the CX Module.?
I have some problems with an 2901 Router because of IPS: When I try to dwonload a file (>5Mb) (hosted in my network) from an external computer It stops in the middle .
I disabled the IPS and everything works perfectly .
I have attached the configurations with IPS Enabled .
Current configuration : 10172 bytes
! Last configuration change at 20:48:01 UTC Tue Sep 17 2013 by admin
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service internal
service sequence-numbers
hostname asdasdasd
boot-start-marker
boot system flash0:/c2900-universalk9-mz.SPA.152-4.M4.bin
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
enable secret 5 $1$..aB$asfghdfghdfghdfghG7o/
enable password 7 110dfghdfghdfghC5A
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
no process cpu extended history
no process cpu autoprofile hog
no ip source-route
ip cef
ip dhcp excluded-address 192.168.1.101 192.168.1.254
ip dhcp pool pool1
import all
network 192.168.1.0 255.255.255.0
dns-server 1455.456.567.1 867.546.345.1
default-router 192.168.1.1
ip dhcp pool Hossdf1
host 192.168.1.2 255.255.255.0
client-identifier 01d4.asd2.8sdf9.3fs
ip dhcp pool swos
host 192.168.1.4 255.255.255.0
client-identifier 04b8.asdff.94dfg7.da
no ip bootp server
ip name-server 455.456.567.1
ip name-server 867.546.345.1
ip inspect log drop-pkt
ip inspect WAAS flush-timeout 10
ip ips config location flash0:/IPS2013V3 retries 1
ip ips notify SDEE
ip ips name sdm_ips_rule
ip ips signature-category
  category all
   retired true
  category ios_ips advanced
   retired false
no ipv6 cef
parameter-map type inspect global
log dropped-packets enable
max-incomplete low 18000
max-incomplete high 20000
spoofed-acker off
parameter-map type ooo global
tcp reassembly timeout 60
tcp reassembly queue length 64
tcp reassembly memory limit 4096
tcp reassembly alarm off
crypto pki trustpoint TP-self-signed-1599122921
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1599122921
revocation-check none
rsakeypair TP-self-signed-1599122921
crypto pki trustpoint test_trustpoint_config_created_for_sdm
subject-name e=sdmtest@sdmtest.com
revocation-check crl
crypto pki certificate chain TP-self-signed-1599122921
certificate self-signed 01
  30820245 308201AE A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31353939 31323239 3231301E 170D3133 30393032 31353536
  35385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 35393931
  32323932 3130819F 6C91963A 2A864886 F70D0101 01050003 818D0030 81890281
  8100A20F 6C91963A 93EA56D8 B2AA3E26 491B4640 BBA28A73 3C086797 5E4189FF
  2C7FFC05 7FBEA959 CD6139C9 9DE34AF1 6B6F3CAF EC4C8681 9356089E A6A16BCD
  52C2967A 69441691 6C91963A 944508EC 783FD7D4 C31C45DB 8A9EA37B 57DC513A
  6275B24D 1C9F2B31 DFA441D4 E37A3429 6ED1B022 C70DD609 4A15B93C 03038927
  1A9D0203 010001A3 6D306B30 0F060355 1D130101 FF040530 030101FF 30180603
  551D1104 11300F82 0D686F73 74696D70 65726172 7472301F 0603551D 23041830
  16801481 81C95CB2 1ABF7800 6FA5040A 63DA2DC9 8EDE6130 1D060355 1D0E0416
  04148181 C95CB21A BF78006F A5040A63 DA2DC98E 6C91963A 06092A86 5E4189FF
  01010405 00038181 007D1A5A 0400EC2F 19DC03BA 7EE3226F 44195F8A 9F89ED84
  EC5E1107 5D1BC74B C26665A2 B5C87E4F 75CCD956 23F9958F 32A5C197 C4381EE1
  7D4CCAD2 6BC29DE3 E0923B3E AFA6B13F 285748F3 6C91963A E0BF5A7D 9C996751
  BBAB6D1A 2D97EB55 9898EDE0 49664A57 5E4189FF 680ECE3C 5E4189FF 6101F88F
  66DE9A5F 9EB86462 6C
      quit
crypto pki certificate chain test_trustpoint_config_created_for_sdm
license udi pid CISCO2901/K9 sn Fss456792sX
license boot module c2900 technology-package securityk9
username sadfmdin privilege 15 secret 5 $1$ZwasdassssssBq.
redundancy
notification-timer 60000
crypto key pubkey-chain rsa
named-key realm-cisco.pub
  key-string
   30820122 300D0609 2A864886 F70D0101 01050003 82010F00 5E4189FF 02820101
   00C19E93 A8AF124A D6CC7A24 5097A975 206BE3A2 06FBA13F 6F12CB5B 4E441F16
   17E630D5 C02AC252 912BE27F 37FDD9C8 11FC7AF7 5E4189FF 43CDABC3 6007D128
   B199ABCB 5E4189FF 49664A57 359C189E F30AF10A C0EFB624 7E0764BF 49664A57
   5B2146A9 D7A5EDE3 0298AF03 DED7A5B8 49664A57 20F30663 9AC64B93 C0112A35
   FE3F0C87 5E4189FF 994AE74C FA9E481D F65875D6 85EAF974 49664A57 F0B08B85
   50437722 49664A57 5E4189FF CC189CB9 69C46F9C A84DFBA5 7A0AF99E AD768C36
   006CF498 079F88F8 A3B3FB1F 49664A57 49664A57 9693CCBB 551F78D2 892356AE
   2F56D826 8918EF3C 49664A57 87BFCA3B BFF668E9 689782A5 CF31CB6E B4B094D3
   F3020301 0001
  quit
no ip ftp passive
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-all sdm-nat--1
match access-group 101
class-map type inspect match-all sdm-nat--2
match access-group 102
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any ccp-cls-insp-traffic
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-invalid-src
match access-group 103
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
policy-map type inspect sdm-pol-NATOutsideToInside-1
class type inspect sdm-nat--1
  inspect
class type inspect sdm-nat--2
  inspect
class class-default
  drop
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class class-default
  drop
policy-map type inspect ccp-permit
class class-default
  drop
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-out-self source out-zone destination self
service-policy type inspect ccp-permit
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security sdm-zp-NATOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-NATOutsideToInside-1
csdb tcp reassembly max-queue-length 128
interface Null0
no ip unreachables
interface Embedded-Service-Engine0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly in
shutdown
interface GigabitEthernet0/0
description $FW_INSIDE$$ETH-LAN$
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
zone-member security in-zone
duplex auto
speed auto
no cdp enable
no mop enabled
interface GigabitEthernet0/1
description $ETH-WAN$$FW_OUTSIDE$
ip address 144.45.134.157 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip verify unicast reverse-path
ip nat outside
ip ips sdm_ips_rule in
zone-member security out-zone
duplex auto
speed auto
no cdp enable
no mop enabled
ip forward-protocol nd
ip http server
ip http access-class 2
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source static 192.168.1.4 85.124.14.138
ip nat inside source static 192.168.1.2 85.124.14.140
ip route 0.0.0.0 0.0.0.0 144.45.134.155
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 2 remark HTTP Access-class list
access-list 2 remark CCP_ACL Category=1
access-list 2 permit 192.168.1.0 0.0.0.255
access-list 2 deny   any
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip 144.45.134.157 0.0.0.127 any
access-list 101 remark CCP_ACL Category=0
access-list 101 permit ip any host 192.168.1.4
access-list 102 remark CCP_ACL Category=0
access-list 102 permit ip any host 192.168.1.2
access-list 103 remark CCP_ACL Category=128
access-list 103 permit ip host 255.255.255.255 any
access-list 103 permit ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip 144.45.134.157 0.0.0.127 any
no cdp run
control-plane
banner login ^CAccess Denied ! ^C
line con 0
transport output telnet
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 104Dsdasdasdasd18
transport input telnet ssh
scheduler allocate 20000 1000
end
We are having two pair of NIPS SSP and working in Active and standby mode.
All four Devices (ASA 5545 and ASA 5525 SSP IPS) showing CPU utilization 100% on both active and standby devices.
Memory usage is also showing very highly utilized.
Kindly help me resovle this issue.
Dheeraj
nikzad_beh
Hi Robert
I have a problem with Add virtual Sensor window - part Interfaces I don't have access to my interfaces and Assign and Remove buttons is gray (not access) what can I do?
