Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
1509
Highlighted
Beginner
Change firepower IPS module from monitor mode to block mode
I want to upgrade 2 cisco asa 5515x to include firepower IPS modules and
  • configure new IPS sensors in monitor mode and add to FMC with new policies
  • post the analysis for any false positives, change the sensors to block mode.
Please guide me how I can achieve this.
Thanks in advance.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Master
Re: Change firepower IPS module from monitor mode to block mode
The Firepower module gets traffic from the parent ASA by applying a service-policy to an interface (or globally). The service-policy references a policy-map which in turn references a class-map.
In the class-map the key command is:
sfr { fail-close | fail-open } [ monitor-only ]
You would use that optional "monitor-only" keyword to operate in IDS mode. When you are ready to move to IPS mode simply change that one line.
Here are some helpful references:
https://www.cisco.com/c/en/us/td/docs/security/asa/asa-command-reference/S/cmdref3/s1.html#pgfId-1660444
https://www.cisco.com/c/en/us/support/docs/security/asa-firepower-services/118644-configure-firepower-00.html#anc10
2 REPLIES 2
Hall of Fame Master
Beginner
Thanks for your response, Marvin.
Content for Community-Ad
August's Community Spotlight Awards
