Cisco ASA Advanced Inspection and Prevention (AIP) Security Services Module
RAINER PARZER
Hi Community
Hope you can help me.
The automatic Signature Update from Cisco.com worked fine on my IPS modules in the past.
Then i updated to 7.3(2)E4 and now it wont update.
Error Message is: AutoUpdate exception: Unknown HTTP exception
Directory: https://www.cisco.com//cgi-bin/front.x/ida/locator/locator.pl
Any Ideas why this happens?
Cisco Intrusion Prevention System, Version 7.3(2)E4
Host:
    Realm Keys               key1.0
Signature Definition:
    Signature Update         S825.0            2014-09-25
    Threat Profile Version   8
OS Version:                  2.6.29.1
Platform:                    ASA5525-IPS
Serial Number:               FCH18087MNT
Licensed, expires:           16-Apr-2017 UTC
Sensor up-time is 5 days.
Using 2992M out of 3484M bytes of available memory (85% usage)
system is using 32.4M out of 160.0M bytes of available disk space (20% usage)
application-data is using 86.0M out of 385.9M bytes of available disk space (23% usage)
boot is using 63.4M out of 77.1M bytes of available disk space (87% usage)
application-log is using 19.3M out of 513.0M bytes of available disk space (4% usage)
MainApp            C-2014_04_14_22_11_7_3_1_48   (Release)   2014-04-14T22:15:32-0500   Running
AnalysisEngine     C-2014_04_14_22_11_7_3_1_48   (Release)   2014-04-14T22:15:32-0500   Running
CollaborationApp   C-2014_04_14_22_11_7_3_1_48   (Release)   2014-04-14T22:15:32-0500   Running
CLI                C-2014_04_14_22_11_7_3_1_48   (Release)   2014-04-14T22:15:32-0500
Upgrade History:
  IPS-K9-7.3-2-E4   17:25:07 UTC Wed Jan 15 2014
Recovery Partition Version 1.1 - 7.3(2)E4
Thanks a lot!
RAINER PARZER
not ideas so far?
does nobody have the same problem?
same issue here with the same OS version :(
connection is open between the Cisco servers and our IPS.
We are using a 5585-X SSP40 IPS module.
If we find something I will let you know, but will probably downgrade again.
thanks.
J
do you use a proxy to access the internet?
it seems that there is a problem with the proxy config!
we used a proxy to access the internet, and it worked over months.
now i access internet without a proxy and it works fine!
