10-09-2014 12:03 AM - edited 03-10-2019 06:15 AM
Hi Community
Hope you can help me.
The automatic Signature Update from Cisco.com worked fine on my IPS modules in the past.
Then i updated to 7.3(2)E4 and now it wont update.
Error Message is: AutoUpdate exception: Unknown HTTP exception
Directory: https://www.cisco.com//cgi-bin/front.x/ida/locator/locator.pl
Any Ideas why this happens?
Cisco Intrusion Prevention System, Version 7.3(2)E4
Host:
Realm Keys key1.0
Signature Definition:
Signature Update S825.0 2014-09-25
Threat Profile Version 8
OS Version: 2.6.29.1
Platform: ASA5525-IPS
Serial Number: FCH18087MNT
Licensed, expires: 16-Apr-2017 UTC
Sensor up-time is 5 days.
Using 2992M out of 3484M bytes of available memory (85% usage)
system is using 32.4M out of 160.0M bytes of available disk space (20% usage)
application-data is using 86.0M out of 385.9M bytes of available disk space (23% usage)
boot is using 63.4M out of 77.1M bytes of available disk space (87% usage)
application-log is using 19.3M out of 513.0M bytes of available disk space (4% usage)
MainApp C-2014_04_14_22_11_7_3_1_48 (Release) 2014-04-14T22:15:32-0500 Running
AnalysisEngine C-2014_04_14_22_11_7_3_1_48 (Release) 2014-04-14T22:15:32-0500 Running
CollaborationApp C-2014_04_14_22_11_7_3_1_48 (Release) 2014-04-14T22:15:32-0500 Running
CLI C-2014_04_14_22_11_7_3_1_48 (Release) 2014-04-14T22:15:32-0500
Upgrade History:
IPS-K9-7.3-2-E4 17:25:07 UTC Wed Jan 15 2014
Recovery Partition Version 1.1 - 7.3(2)E4
Thanks a lot!
10-21-2014 06:27 AM
not ideas so far?
does nobody have the same problem?
11-15-2014 04:23 AM
same issue here with the same OS version :(
connection is open between the Cisco servers and our IPS.
We are using a 5585-X SSP40 IPS module.
If we find something I will let you know, but will probably downgrade again.
thanks.
J
11-16-2014 11:05 PM
do you use a proxy to access the internet?
it seems that there is a problem with the proxy config!
we used a proxy to access the internet, and it worked over months.
now i access internet without a proxy and it works fine!
