Once you have Generated (and Use) Firepower Recommendations in your Intrusion Policy, the system does not change them unless and until you choose to "Update Recommendations" manually or create a scheduled task to do so for you (and deploy policy afterwards). You would do the latter via System > Tools > Scheduling. Create a new task and choose job type "Firepower Recommended Rules".
The "Recurring Rule Updates" are indeed the vrt (Vulnerability Research Team) files which comprise the Snort Rule Updates (SRU).
