configure an excepcion for a host in an IPS4260
Luis Carranza
Hi guys!!
I need your help to know if it's possible to configure an excepcion for a specific host or ip address in an IPS 4260, I can do this in an AIP-SSM configuring an access-list, but I think it's different on an appliance.
raga.fusionet
Level 4
Level 4
Hi Luis,
An exception on IPS is called an event action filter, I was looking for a config example but instead I found this nice youtube video:
http://www.youtube.com/watch?v=Ho945eUSwbo
If you have a host that is firing a lot of false positives just select it as "attacker" and leave the signature range blank if you dont want to see any signature at all coming from this guy.
I hope this helps.
Raga
5 Replies 5
raga.fusionet
Level 4
Level 4
Hi Luis,
I hope this helps.
Raga
Thinking about it, I dont think blank works. You can enter a single signature ID, a  comma-separated list, or a range of IDs. The default is to apply the  rule to signatures in the range 900-65535.
Luis is correct, you want to configure an Event Action Filter for your host IP.
Here's the documentation page for 7.0 CLI:
http://www.cisco.com/en/US/docs/security/ips/7.0/configuration/guide/cli/cli_event_action_rules.html#wp1030749
- Bob
Thanks Luis
This was really helpful!!!
Awesome, Glad I could help
Have a good one!
