Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
306
Highlighted
Rising star
Configuring CSC-SSM
From what I've been reading about the SSM module is that there is a Base License and a Plus License.
The Base license allows the SSM module to do basic antivirus/spyware checking on your network. The Plus
License allows the Base License, Plus URL Filtering and Email filtering.
So, I'm assuming that the only way to block malicious web sites and URL filtering is through the SSM?
I guess you could also just apply ACLs but the best way would be through the SSM.
If you purpose the CSC-SSM with Plus LIcense, and configure it, will there by any downtime associated with it,
when you switch the traffic being forwarded to the CSC from the ASA instead of just going out to the ASA and
to the Internet?
Thanks for your help guys
Everyone's tags (2)
1 ACCEPTED SOLUTION
Configuring CSC-SSM
Hello John,
I guess you could also just apply ACLs but the best way would be through the SSM?
A/     Well as the name said this is a content filtering device, he will apply policies based on what you configured, on the other hand the IPS-SSM will allow al traffic denying only the ones he found is ilegal so I would say yes you are right.
to the Internet?
A/ No downtime at all, just remember to have the CSC previously setup, a fail-open policy would be great and finally just redirect the traffic to see it working. As soon as the CSC is up and running there will be a peace association
Remember to rate all the helpful posts
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
3 REPLIES 3
Configuring CSC-SSM
Hello John,
to the Internet?
Julio
Julio Carvajal
Rising star
Configuring CSC-SSM
Thanks for the help jcarvaja. From what I was reading, it looks lilke the best way to go is, make sure to configure the CSC-SSM, so that if the module fails traffic passes as usual.
Once again Jcarvaja, thanks for the help.
Configuring CSC-SSM
Hello John,
It is always a pleasure to help
Julio
Julio Carvajal
Content for Community-Ad
August's Community Spotlight Awards
