Firepower 7010 - what type of power cable?
pascoej
I have a Firepower 7010 with no power lead. What type of power cable do I need to search for online?
I searched the data sheets on cisco.com, but the power cord stipulated is not correct (IEC C13/14). I have attached a picture of the interface I require a power cable for.
Marvin Rhoads
It's a part called "FP-PWR-BRICK=". The C13/C14 goes from the mains supply to the "brick" itself which has the built-in AC-DC converter.
They are still sold by Cisco. List price is US$300. You may find them from 3rd party resellers as well.
6 Replies 6
Marvin Rhoads
Many thanks Marvin, that's very helpful!
Hi Marvin. I too have this problem, no power supply. I do have a plug that fits the power socket in my Firepower 7030 but is the wrong voltage. Would you happen to know what the pinout is for the FP-PWR-BRICK= is as I would be able to adapt another 12V power supply to suit.
Sorry but I don't have the pinout information. As far as I can tell it's not published in any Cisco specification.
Hi Marvin, Thanks anyway, I didn't think it would have been published. What I did though was put my multimeter between the black wire pins on the feed to the HDD and pinned out the connector. I found that the bottom two pins were directly connected and that the top two pins weren't. The top two are then the +12vdc feed. I hooked it up to my bench power supply, gave it 12vdc and it worked. Saved myself $250+.
Nice work! Thanks for sharing your solution.
