Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
948
Beginner
Firepower 7010 - what type of power cable?
I have a Firepower 7010 with no power lead. What type of power cable do I need to search for online?
I searched the data sheets on cisco.com, but the power cord stipulated is not correct (IEC C13/14). I have attached a picture of the interface I require a power cable for.
1 ACCEPTED SOLUTION
Hall of Fame Master
Re: Firepower 7010 - what type of power cable?
It's a part called "FP-PWR-BRICK=". The C13/C14 goes from the mains supply to the "brick" itself which has the built-in AC-DC converter.
They are still sold by Cisco. List price is US$300. You may find them from 3rd party resellers as well.
6 REPLIES 6
Hall of Fame Master
Beginner
Many thanks Marvin, that's very helpful!
Beginner
Hi Marvin. I too have this problem, no power supply. I do have a plug that fits the power socket in my Firepower 7030 but is the wrong voltage. Would you happen to know what the pinout is for the FP-PWR-BRICK= is as I would be able to adapt another 12V power supply to suit.
Hall of Fame Master
Sorry but I don't have the pinout information. As far as I can tell it's not published in any Cisco specification.
Beginner
Hi Marvin, Thanks anyway, I didn't think it would have been published. What I did though was put my multimeter between the black wire pins on the feed to the HDD and pinned out the connector. I found that the bottom two pins were directly connected and that the top two pins weren't. The top two are then the +12vdc feed. I hooked it up to my bench power supply, gave it 12vdc and it worked. Saved myself $250+.
Hall of Fame Master
Nice work! Thanks for sharing your solution.
Content for Community-Ad
July's Community Spotlight Awards
