High CPU on ASA 5515-IPS
Jerome ALLEAU
I just upgrade my IPS from 7.1(4)E4 to 7.1(6)E4. I have no more Application failed failures, but i'm still facing 100% CPU, and almost 80% memory, without any load!
Any clue to help me where to search?
Best regards
10 Replies 10
sawgupta
CPU usage is not the correct indicator of Load.
You should check the 'Inspection Load" value. It will tell how much the appliance is actually loaded.
Sawan Gupta
Thanks & Regards, Sawan Gupta
Here is what i've got with a show inspection load history :
100 +
80 +
60 +
40 +
20 +
              10        20        30        40        50
      Inspection Load per minute (last 60)  * = max %  # = avg %
100 +
80 +
60 +
40 +
20 +
              10        20        30        40        50        60        70
             Inspection Load per hour (last 72)  * = max %  # = avg %
And here's the cpu :
section CPU Statistics
      Usage over last 5 seconds 100
      Usage over last minute 100
      Usage over last 5 minutes 100
I read that there was a Case open for that problem :
CSCtl74475  CPU usage statistics are not relevant.
But this should be resolved, since the 7.1(5)E4 :
http://www.cisco.com/web/software/282549759/94912/IPS-7-1-6-E4.readme.txt
Is there something else, or something new, that could explain this kind of behavior?
We are running an ASA 5525-X (not in production) with IPS SSP Module running at IPS version 7.1(6)E4 and are seeing the same behavior.
CPU 100%
Inspection load 0
It seems like this might still be a bug, but none of the release notes indicate that the bug still exists. I read the same release notes you did and it seems like it was supposed to have been resolved in 7.1(5)E4.
I have the same behavior with a ASA 5585X with IPS SSP10 - CPU 100% on 3 of the 4 cores and the last idle - inspection 0 - it is not mapped in yet
Ok guys.
Thanks for those responses.
Hi all,
I've upgraded to the latest version 7.1(7P1)E4 today but still running at 100% on my 5525X. This is without diverting any traffic to the IPS s/w so I'd say the issue still remains.
Dean
Service Desk
Hi All,
We are also observing this problem. The fix listed in CSCtl74475   is to "not use cpu statistics" and rely on the inspection load statistics instead. Pretty poor in my opinion. Cisco should be either trying to fix the problem (CPU utilisation seemed to work fine on IPS modules running earlier version of the IPS software) or remove the feature/function entirelly?
Hi All.
We have a ASA 5525-X and are also experiencing CPU 100%
Inspection load is 0-3%
We use the IPS 7.1(7)E4 and it sill hasn't been fixed........
Greetings
jarle
lcambron
Level 3
Level 3
Just in case, be aware of:
https://supportforums.cisco.com/thread/2247763?tstart=0
Felipe.
