How does IOS IPS affect throughput performace?
m.renshaw
Hi Support people,
I have been trialling IOS IPS on a number of Cisco ISRg2 routers and I have found that after enabling it the CPU jumps to 99% and I see packet drops (ingress) on the interface that IPS is applied.
Has anyone else successfully deployed IOS IPS? If yes what router/s have you used and what did you do to mitigate high CPU usage and packet drops?
Thank you in advance for all of your quick reply’s
svaish
Using IOS-IPS is recommended for some very basic use and small deployments only.
As there are limited resources available on the router; using IOS IPS has a direct impact on the speed/throughput of the router and generally not recommended to enable most of signature on it.
We only recommend enabling some  very basic signature package on the IOS-IPS for basic packet inspection.
Enabling all the signatures can result in high CPU on the router as well.'
Datasheet
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6634/product_data_sheet0900aecd803137cf.html
Getting Started with IOS IPS ― A Step-by-Step Guide
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6634/prod_white_paper0900aecd805c4ea8.html
The above guide will be very helpful.
Sachin
