Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
1519
Highlighted
Beginner
IME v7.2.4.50 fails to manage ASA5515-IPS v7.2(1)E4
IME v7.2.4.50 working fine with some ASA-SSM-10 and -20 v7.1(8)E4.
Just added two ASA5515-IPS v7.2(1)E4, and when I try to configure anyone of them, this is issued:
"Sensor version 7.2(1)E4 is not supported by the integrated Configuration feature of this application.
The integrated Configuration feature is available only from sensors running software version 6.1(1) and later.
However, you can configure this sensor using the IPS Device Manager (IDM). To do this direct you browser to https://w.x.y.z."
I installed IME v7.2.4 (no-.50) in another Windows and it works.
Is there some adjustment to be done in IME v7.2.4.50 to be able to manage ASA5515-IPS v7.2(1)E4?
I found nothing in the release notes about that.
Hugo
8 REPLIES 8
Beginner
Any luck with this Hugo?  I am having the exact same issue with IME 7.2.4.50 and my 7.2.1 5515-X boxes.
Rob
Beginner
Hi Rob,
No, unfortunately I still have the problem, no one answered to this thread.
I tried to uninstall IME v7.2.4.50, restart, installed IME v7.2.4, reboot, same problem.
I did not try to remove Cisco registry entries and/or folders/files that IME creates, maybe someone has a more elegant advice.
Hugo
Beginner
Mine was a fresh install of 7.2.4.50.  I will have to open a case with TAC to troubleshoot.  Will update you when i have more info.
Beginner
OK, please let us know what they tell you.
Beginner
Re: IME v7.2.4.50 fails to manage ASA5515-IPS v7.2(1)E4
It looks like a bug that they know about internally.  They will be making the notes publicly available soon.  See email correspondence below:
This is due to a known issue - CSCul06870. The Workaround for this is to install IME version 7.2.4 instead (for managing/monitoring IPS 7.2(1)E4 devices).
I am going to update the defect's Release Note to make it externally-visible, after which it will be screened/approved and eventually (generally takes a few business days) visible here:
  https://tools.cisco.com/bugsearch/bug/CSCul06870
Beginner
OK, thanks.
Hugo
Beginner
This has been resolved.  They reposted the executable on October 31st but did not increment the version number.  I installed over my existing 7.2.4.50 version, rebooted, and verified that I was able to configure both of my IPS modules.
"I discussed this with the IME Development team and they informed me that they re-posted a fixed version of IME to cisco.com. Unfortunately, they decided not to increment the version number, so the fixed version is also 7.2.4.50."
Beginner
Rob,
I downloaded the new file and installed it over the already installed IME.
It worked fine without rebooting.
Thanks for your help.
Hugo
Content for Community-Ad
FusionCharts will render here
