Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
227
Beginner
Kamasutra Signature
Is the Kamasutra worm signature available? If it is not available yet... is ther any workaround to detect and prevent the worm?
3 REPLIES 3
Beginner
Re: Kamasutra Signature
Correct me if I am wrong however this looks to be another alias for the blackworm. There was a custom signature provided under the blackworm thread:
In the meantime you can use the following custom signature to catch WORM_GREW.A also known as W32.Blackmal.E@mm, W32/Kapser.A@mm, W32/MyWife, Win32/Blackmal.F:
Engine: String.TCP
Service Port: 25
Regex String :
\x6d\x41\x70\x4d\x6a\x74\x64\x4e\x45\x51\x78\x4a\x7a\x49\x6a\x53\x79\x46\x49\x4f\x44\x30\x4e\x43\x6b\x31\x4b\x57\x6c\x51\x70\x4e
Highlighted
Beginner
I'm new to creating rules. Can you give me the steps needed to create this rule using the IDM Gui interface to a 4255 running 5.0? Things like what engine to use and where to put the Regex string.
Go to
Configuration | Signature Definition | Signature Configuration
Click on the "Add" button.
-> New popup with the signature parameters
Select String TCP as an engine
->New parameters appear
Configure "Regex String" and "Service Ports" as mentionned previously.
Click "OK"
Click "APPLY"
Content for Community-Ad
August's Community Spotlight Awards
