Kamasutra Signature
facundog
Is the Kamasutra worm signature available? If it is not available yet... is ther any workaround to detect and prevent the worm?
jlimbo
Correct me if I am wrong however this looks to be another alias for the blackworm. There was a custom signature provided under the blackworm thread:
In the meantime you can use the following custom signature to catch WORM_GREW.A also known as W32.Blackmal.E@mm, W32/Kapser.A@mm, W32/MyWife, Win32/Blackmal.F:
Engine: String.TCP
Service Port: 25
Regex String :
\x6d\x41\x70\x4d\x6a\x74\x64\x4e\x45\x51\x78\x4a\x7a\x49\x6a\x53\x79\x46\x49\x4f\x44\x30\x4e\x43\x6b\x31\x4b\x57\x6c\x51\x70\x4e
I'm new to creating rules. Can you give me the steps needed to create this rule using the IDM Gui interface to a 4255 running 5.0? Things like what engine to use and where to put the Regex string.
Go to
Configuration | Signature Definition | Signature Configuration
Click on the "Add" button.
-> New popup with the signature parameters
Select String TCP as an engine
->New parameters appear
Configure "Regex String" and "Service Ports" as mentionned previously.
Click "OK"
Click "APPLY"
