04-04-2017 01:46 PM - edited 03-10-2019 06:48 AM
I need to enable the Firepower NGIPS in a ASA5515X together with the virtual Firepower Management Center. Can you confirm that the following part-numbers are the corrects considering that I want to activate the anti-malware protection?
Thanks in advance!
Solved! Go to Solution.
04-04-2017 08:11 PM
Your list would cover it with the following notes:
You have included the SSD (and support contract for the same) which is only necessary if the existing unit was one of the early 5515-Xs shipped without one. You should confirm that with "show inventory".
The "TAMC" license type includes IPS, URL Filtering and Malware protection features.
The virtual FirePOWER Management Center requires the customer provide a suitable VMware ESXi host to be able to deploy the VM.
04-05-2017 12:35 AM
Antonio,
ASA5515-FP-UPG is not a license by itself. It is an ordering SKU (stock keeping unit) that will prompt the reseller in Cisco Commerce Workspace (CCW) to select all of the individual options and part numbers (i.e., the ones you listed separately) necessary to build a complete validated configuration.
If you are a partner, please also refer to the Network Security Ordering Guide. It can be found here:
https://communities.cisco.com/docs/DOC-70838 (partner level access required)
I hope this makes it clear. Please rate / mark your question as answered if it does.
04-04-2017 08:11 PM
04-04-2017 11:45 PM
Thanks Marvin.
I can confirm that the ASA does not have the SSD incorporated. I'm also aware of the VMware requirements for the Management Center.
One additional question, what is the purpose of the upgrade license ASA5515-FP-UPG then? Is it a single license that includes all the previous items in the list?
Regards.
04-05-2017 12:35 AM
Antonio,
04-05-2017 12:42 AM
Much more clear now.
Thanks Marvin!
05-02-2019 02:22 AM
Can i use "TAMC" license type with 5516
Below is firewall output
Name: "Chassis", DESCR: "ASA 5516-X with FirePOWER services, 8GE, AC, DES"
PID: ASA5516 , VID: V05 , SN: JMX2142G1J2
Name: "Storage Device 1", DESCR: "ASA 5516-X SSD"
PID: ASA5516-SSD , VID: N/A , SN: MSA213003YS
want to use this
L-ASA5516-TAMC-1Y
05-09-2019 08:40 AM
Yes, you can use that license.
You would also require the (no cost) Control license.
