05-09-2016 08:09 PM - edited 03-10-2019 06:37 AM
Hi Team,
Kindly help me on resetting the password ASA CX5512 module on HA ASA setup.
Thanks in advance!
Mady
05-10-2016 12:25 PM
On each ASA, you'll need to use the command 'sw-module module cxsc password-reset'.
I don't remember the exact procedure now, but that will get you pretty close.
05-10-2016 08:14 PM
That's correct, Philip
To reset the password on the software module to the default value, use the sw-module module password-resetcommand in privileged EXEC mode.
The default password will then be set. For the CX module it is Admin123.
Reference:
http://www.cisco.com/c/en/us/td/docs/security/asa/asa-command-reference/S/cmdref3/s17.html
05-12-2016 06:44 PM
Thanks Philip and Marvin!
