I have an scenario where one host tries to copy a file via scp to another and the transfer stalls. Between these hosts there is an ASA with an SSM module. Tests show that when the IPS is disabled the file transfer completes in a successful way.
Anybody has seen a similar issue and has solved it?
Is a particular signature firing during the file transfer ? Please check "show events" on IPS CLI.
If a signture has fired, it may reset the connection based on the configuration.
Sawan Gupta
Thanks & Regards,
Sawan Gupta
