11-09-2016 01:28 PM - edited 03-10-2019 06:42 AM
We recently began receiving the following sftunnel SSL errors on several FirePower devices. Devices have lost their connection to the FireSight and cannot be registered. Thanks in advance, for any helpful information you can provide.
Excerpt from /var/log/messages provided below:
/var/log/messages on FirePower:
Nov 8 00:09:06 <FirePower_hostname>SF-IMS[7636]: [7936] sftunneld:sf_ssl [ERROR] Accept:SSL handshake failed
Nov 8 00:09:06 <FirePower_hostname>SF-IMS[7636]: [7936] sftunneld:sf_ssl [WARN] SSL Verification status: ok
Nov 8 00:09:13 <FirePower_hostname>SF-IMS[7636]: [7948] sftunneld:sf_ssl [INFO] Processing connection from <FireSight_IP>:55444/tcp (socket 10)
Nov 8 00:09:13 <FirePower_hostname>SF-IMS[7636]: [7948] sftunneld:sf_ssl [ERROR] Accept:SSL handshake failed
Nov 8 00:09:13 <FirePower_hostname>SF-IMS[7636]: [7948] sftunneld:sf_ssl [WARN] SSL Verification status: ok
Nov 8 00:09:35 <FirePower_hostname>SF-IMS[7636]: [7646] sftunneld:sf_ssl [ERROR] Unable to connect to port 8305 (IPv4): Connection timed out
Nov 8 00:09:36 <FirePower_hostname>SF-IMS[7636]: [7985] sftunneld:sf_ssl [INFO] Initiate IPv4 connection to <FireSight_IP>
Nov 8 00:09:36 <FirePower_hostname>SF-IMS[7636]: [7985] sftunneld:sf_ssl [INFO] Initiating IPv4 connection to <FireSight_IP>:8305/tcp
Nov 8 00:12:45 <FirePower_hostname>SF-IMS[7636]: [7985] sftunneld:sf_ssl [ERROR] Unable to connect to port 8305 (IPv4): Connection timed out
Nov 8 00:12:54 <FirePower_hostname>SF-IMS[7636]: [8268] sftunneld:sf_ssl [INFO] Initiate IPv4 connection to <FireSight_IP>
Nov 8 00:12:54 <FirePower_hostname>SF-IMS[7636]: [8268] sftunneld:sf_ssl [INFO] Initiating IPv4 connection to <FireSight_IP>:8305/tcp
/var/log/messages on FireSight:
Nov 8 00:09:21 <FIRESIGHT_HOSTNAME> SF-IMS[1854]: [11439] sftunneld:sf_ssl [INFO] Connected to <sensor_IP>:8305 (IPv4)
Nov 8 00:09:22 <FIRESIGHT_HOSTNAME> SF-IMS[1854]: [11439] sftunneld:sf_peers [INFO] Delete:Free SSL_CONTEXT for peer <sensor_IP>
Nov 8 00:09:28 <FIRESIGHT_HOSTNAME> SF-IMS[1854]: [11446] sftunneld:sf_ssl [INFO] Initiate IPv4 connection to <sensor_IP>
Nov 8 00:09:28 <FIRESIGHT_HOSTNAME> SF-IMS[1854]: [11446] sftunneld:sf_ssl [INFO] Initiating IPv4 connection to <sensor_IP>:8305/tcp
Nov 8 00:09:28 <FIRESIGHT_HOSTNAME> SF-IMS[1854]: [11446] sftunneld:sf_ssl [INFO] Connected to port 8305 (IPv4): <sensor_IP>
Nov 8 00:09:28 <FIRESIGHT_HOSTNAME> SF-IMS[1854]: [11446] sftunneld:sf_ssl [INFO] Connected to <sensor_IP>:8305 (IPv4)
Nov 8 00:09:29 <FIRESIGHT_HOSTNAME> SF-IMS[1854]: [11446] sftunneld:sf_peers [INFO] Delete:Free SSL_CONTEXT for peer <sensor_IP>
Nov 8 00:09:35 <FIRESIGHT_HOSTNAME> SF-IMS[1855]: [1855] sfmgr:sfmanager [INFO] set peer PEER_REMOVED pending <sensor_IP>
Nov 8 00:09:35 <FIRESIGHT_HOSTNAME> SF-IMS[1855]: [1855] sfmgr:sfmanager [INFO] free_peer <sensor_IP>.
Nov 8 00:09:35 <FIRESIGHT_HOSTNAME> SF-IMS[1854]: [11531] sftunneld:sf_ssl [INFO] Initiate IPv4 connection to <sensor_IP>
Nov 8 00:09:35 <FIRESIGHT_HOSTNAME> SF-IMS[1854]: [11531] sftunneld:sf_ssl [INFO] Initiating IPv4 connection to <sensor_IP>:8305/tcp
Nov 8 00:09:35 <FIRESIGHT_HOSTNAME> SF-IMS[1854]: [1854] sftunneld:sftunnel [INFO] set peer PEER_REMOVED <sensor_IP> pending
Nov 8 00:09:35 <FIRESIGHT_HOSTNAME> SF-IMS[1854]: [11531] sftunneld:sf_ssl [INFO] Connected to port 8305 (IPv4): <sensor_IP>
Nov 8 00:09:35 <FIRESIGHT_HOSTNAME> SF-IMS[1854]: [11531] sftunneld:sf_ssl [INFO] Connected to <sensor_IP>:8305 (IPv4)
Nov 8 00:09:36 <FIRESIGHT_HOSTNAME> SF-IMS[1854]: [11531] sftunneld:sf_peers [INFO] Delete:Free SSL_CONTEXT for peer <sensor_IP>
11-10-2016 02:39 PM
Has anything changed in your environment recently (fmc / sensor upgrade?). You said that device could not be registered - so have they not been added to the fmc yet or are they just not able to reconnect?
In any case check your manager configuration on sensor side (fqdn used? -> maybe dns issues) and try to restart the sftunnel process on both sensor and fmc... Normally FMC should connect in < 5min to the sensor again successfully.
Restart sftunnel via pmtool: pmtool restartById sftunnel
09-04-2023 01:05 PM
Experiences the same issue on FMC and FTD on version 7.2.4.
After I issued the "pmtool restartById sftunnel" on both sides, the registration went through with success.
