Signature 31020 appears to be alerting to a massive amount of false positives
PronetMSSP
Has anyone else ran into an issue with sig 31020 alerting to false positives?
7 Replies 7
m.vuckovic
Hi. I see the same situation in my LAN environment especialy between Windows Servers. No information about possible benign triggers. It's a fresh signatue (S527) so I guess a little tuning from Cisco can be expected.
Best regards,
Marko
Thank you for the reply.  Hopefully they tune it sooner than later.  We're getting way too many alerts.
-Cory
It is very important to check if this traffic is matching agains the signature. Take a packet capture of the traffic and share it with us so we can check if the signature is being triggered for no reason.
Cheers
Mike.
Mike
Maykol.
I'm attaching two captured flows(log pair command on IPS) which triggered alarm 31020.
Best regards,
Marko
Marko,
Thanks for the packet capture, I was taking a look at them and I found out that in Frame 36 on capture sig31020-1 the user given is (/) which may be considered a Null username by the IPS, is there a reason as of why users are being logged as (/) ?
Here is the link that explains about the signature
http://tools.cisco.com/security/center/viewIpsSignature.x?signatureId=31020&signatureSubId=0
Let me know.
Cheers.
Mike
Mike
Thank you for your answer.
I really don't know the answer. I'll try to find out the reason for this but I have not much hope to find the answer.
Best regards,
Marko
This fires all the time for us now.  Cisco reports that this sig replaced sig 5577/1.  5577/1 has almost never fired on us.  Now 31020 fires from hundreds of sources each day.
What changed from 5577/1 to 31020/0?
Is Cisco looking into this?
