02-17-2014 06:29 AM - edited 03-10-2019 06:08 AM
I'm unable to connect to IPS by using IME. I have also configured (tls generate-key) but not able to connect. Here is the below error.
"IOExecption when try to get certificate : connection refused"
Parosh
02-18-2014 05:41 AM
Hello Mizanul,
Is your IME server able to connect to IPS over HTTPS?
Check it in your Firewall if you have in the middle of the connection...
And apply an access-list in the IPS to allow that connection!
Good luck!
Diego
02-19-2014 03:11 AM
A. In order to solve this error message, login into the AIP-SSM and issue the tls generate-key command in privileged EXEC mode as shown in this example:
sensor#tls generate-keyNote: This resolution of using the command tls generate-key also resolves the issue of AIP-SSM not being able to connect to the IME.
02-20-2014 10:46 AM
Hi Saurav Lodh,
Thanks for reply, still i'm unable to connect IPS using IME. I have configured this command but not solved the problem. Do you describe what is the actual problem.
Parosh
