Unable to Connect IPS by IME
Mizanul Islam
I'm unable to connect to IPS by using IME. I have also configured   (tls generate-key) but not able to connect. Here is the below error.
"IOExecption when try  to get certificate : connection refused"
Parosh
Hello Mizanul,
Is your IME server able to connect to IPS over HTTPS?
Check it in your Firewall if you have in the middle of the connection...
And apply an access-list in the IPS to allow that connection!
Good luck!
Diego
Saurav Lodh
Level 7
Level 7
Q.   The "IOException when try to get certificate:   java.security.cert.CertificateExpiredException". error message   appears. How this can be resolved?
A. In order to solve this error message, login into the AIP-SSM and issue       the tls       generate-key command in privileged EXEC mode as shown in       this example:
sensor#tls generate-key
Note: This resolution of using the command tls           generate-key also resolves the issue of AIP-SSM not being           able to connect to the IME.
Hi Saurav Lodh,
Thanks for reply, still i'm unable to connect IPS using IME. I have configured this command but not solved the problem. Do you describe what is the actual problem.
Parosh
