01-02-2013 07:32 AM - edited 03-16-2019 02:57 PM
I have 1750 router with c1700-sv3y-mz.122-26c.bin image but it does not recognize my FXO/FXS mod. what am I doing wrong.
IOS (tm) C1700 Software (C1700-SV3Y-M), Version 12.2(26c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Mon 30-Jul-07 17:18 by ccai
Image text-base: 0x800080E0, data-base: 0x80B2FA24
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
Router uptime is 9 minutes
System image file is "flash:c1700-sv3y-mz.122-26c.bin"
cisco 1750 (MPC860) processor (revision 0x601) with 36864K/12288K bytes of memory.
Processor board ID JAD041704WN (1636194690), with hardware revision 0000
M860 processor: part number 0, mask 32
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Configuration register is 0x2102.
thanks
01-02-2013 07:40 AM
Hi Samir,
Looking at the data sheet of this router, it should be able to support a VIC-2FXS card (1st Gen):
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080092102.html
As per VIC-2FXS data sheet, the current IOS and feature set should support the card as well:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a0080094fac.shtml#support
On the Cisco 1700 voice platforms, one or more packet voice and data modules (PVDMs) are needed to support Voice interface card (VICs,) or voice ports may be missing in the active configuration. The PVDMs hold digital signal processors (DSPs) that make the VICs fully functional, and are installed on the motherboard of the Cisco 1700 series.
For more information, refer to:
http://www.cisco.com/en/US/products/hw/routers/ps221/products_tech_note09186a00800c3399.shtml
HTH.
Harmit.
01-02-2013 07:56 AM
thanks Harmit.
I ran sh diag and this is what I got.
sh diag
Slot 0:
C1750 1FE VE Mainboard Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 6.1
PCB Serial Number : JAD041704WN
Part Number : 73-3743-06
Board Revision : A0
Fab Version : 04
EEPROM format version 4
EEPROM contents (hex):
Packet Voice DSP Module Slot 0:
Not populated
WIC Slot 1:
Dual FXO Voice Interface Card
Hardware revision 1.1 Board revision J0
Serial number 0026692362 Part number 800-02495-01
Test history 0x00 RMA number 00-00-00
Connector type WAN Module
EEPROM format version 1
sh voice port sum
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
does this mean that I need to purchase PVDM?
01-02-2013 08:00 AM
Hi Samir,
Yes, looks like the PVDM slot is empty:
Not populated
I also noticed that you dont have an FXS card, instead, you have an FXO??
WIC Slot 1:
Please crosscheck the data sheets to ensure the card you have is supported and also look at getting PVDM module to get the router to detect the card.
HTH.
Please rate helpful posts.
Harmit.
01-02-2013 08:06 AM
Sorry about the little confusion, but I also have fxs card and that did not work ether.
now I am not sure if it is worth spending the money on the mod. I think I should buy another fxo/fxs/nm2v cards and install in my other 2600.
thanks for your replies and I realy do appreciate your quick replies.
01-02-2013 08:11 AM
Hi Samir,
No worries mate, I am glad I could be of help! :-)
Depends on what you want to use the router for. It is quite outdated including the IOS. To get the most out of the features available, I would say look at an ISR atleast. If you dont require too many features, then 2600 will also do.
Kindly mark this thread as answered, much appreciated.
Harmit.
