09-21-2016 12:08 AM - edited 03-17-2019 08:08 AM
Dear All,
Can we have 2 Unity cluster with 1 CUCM cluster..? as we want to have separate unity cluster at Branch side.
IB
Solved! Go to Solution.
09-21-2016 05:01 AM
Hi Irfan,
I have seen this deployment work in many cases, you can check the section "Configuration of Multiple Cisco Unity Connection Clusters Integrated with One Cisco Unified Communications Manager Server" of the following link to get a confirmation that this is supported
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cupa/visual_voicemail/8-5/install/guide/vv_install/cluster_failover.html#wp1055747
Manish
09-21-2016 01:07 AM
Hi Irfan,
Yes, it is possible. You may study the available Unity Connection deployment models here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/9x/design/guide/9xcucdgx/9xcucdg050.html#85623
Manish
09-21-2016 01:28 AM
Hi Manish,
How you doing. Thanks for your quick response.
On cisco site and in deployment models it says Multiple CUCM cluster to single Unity Cluster but not vice versa(Multiple Unity Clus to Single CUCM Clus).
IB
09-21-2016 05:01 AM
Hi Irfan,
Manish
09-21-2016 05:45 AM
Thanks manish...That really helped.
