2650XM with VWIC-1MFT-T1 Layer 1 Status is "DEACTIVATED"
asafayan
Level 4
Level 4
I have a VWIC card that I'm trying to bring up on a Voice PRI circuit.  I am off-site and don't have physical access to the card.  I've tried new patch cables and reseated the card but I can never get the Layer Status beyond "Deactivated".  sh diag does indicate that the card is properly recognized.
1#sh isdn status
Global ISDN Switchtype = primary-dms100
ISDN Serial0/0:23 interface
        dsl 0, interface ISDN Switchtype = primary-dms100
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 1
    Total Allocated ISDN CCBs = 0
asandborgh
Level 4
Level 4
If you have changed the cable than very likely the carrier has not properly activated it (the circuit via the smartjack/DMARC).  I would call them before burning a bunch of extra time.
HTH,
Art
5 Replies 5
asafayan
Level 4
Level 4
show run follows:
version 12.4
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
boot-start-marker
boot system flash:c2600-advipservicesk9-mz.124-25c.bin
boot-end-marker
logging buffered 4096 notifications
aaa new-model
aaa authentication login default group radius local
aaa authentication login no-radius line
aaa authentication enable default enable
aaa authorization exec default group radius if-authenticated
aaa accounting exec default start-stop group radius
aaa session-id common
memory-size iomem 10
no network-clock-participate slot 1
network-clock-participate wic 0
network-clock-select 1 T1 0/0
voice-card 0
dspfarm
no local-bypass
voice-card 1
dspfarm
ip cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
isdn switch-type primary-dms100
voice service voip
h323
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
h225 timeout tcp establish 10
voice translation-profile SRST_Profile
translate called 1
controller T1 0/0
framing esf
linecode b8zs
pri-group timeslots 1-24
class-map match-any RealTime
match access-group 105
class-map match-any BurstyLo
match access-group 102
class-map match-any NetControl
match access-group 106
match access-group 108
class-map match-any BurstyHi
match access-group 103
class-map match-any CoS7
match access-group 107
class-map match-any CoS6
class-map match-any CoS5
class-map match-any CoS3
class-map match-any CoS2
policy-map Egress_WAN_QoS
class RealTime
  priority 308
class BurstyLo
  bandwidth remaining percent 30
class BurstyHi
class NetControl
  set dscp cs6
class class-default
  bandwidth remaining percent 10
  random-detect
  set dscp default
policy-map LAN_QoS_Policy
class CoS7
  set cos 7
class CoS6
  set cos 6
  set dscp cs6
class CoS5
  set cos 5
class CoS3
  set cos 3
class CoS2
  set cos 2
class class-default
  set cos 0
interface Loopback0
description Interface for IPT Gateway (MGCP, SCCP, H.323)
ip address 10.34.5.1 255.255.255.255
no ip redirects
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.34.5.1
interface FastEthernet0/0
description Connection to LAN
no ip address
speed 100
full-duplex
interface FastEthernet0/0.20
description Sub-interface for VLAN 20
encapsulation dot1Q 20
ip address 10.34.20.1 255.255.255.0
no ip redirects
service-policy output LAN_QoS_Policy
interface Serial0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
ip default-gateway 10.34.20.254
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 10.34.20.50
no ip http server
no ip http secure-server
access-list 7 permit 10.0.1.62
access-list 7 permit 10.110.0.0 0.0.255.255
access-list 10 permit 10.0.0.0 0.255.255.255
access-list 102 permit ip any any dscp af21
access-list 103 permit ip any any dscp af31
access-list 103 permit ip any any precedence flash
access-list 105 permit ip any any dscp ef
access-list 105 permit ip any any precedence critical
access-list 106 permit ip any any dscp cs6
access-list 107 permit ip any any dscp cs7
access-list 108 permit tcp any eq 22 any
access-list 108 permit tcp any any eq 22
snmp-server enable traps tty
control-plane
voice-port 0/0:23
ccm-manager redundant-host 10.110.20.22 10.110.20.20
ccm-manager music-on-hold
dial-peer cor custom
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 2 voip
description Inbound VoIP DP - H.323
voice-class codec 1
voice-class h323 1
dtmf-relay cisco-rtp h245-signal h245-alphanumeric
ip qos dscp cs3 signaling
no vad
dial-peer voice 3 voip
description Inbound VoIP DP - SIP
voice-class codec 1
session protocol sipv2
session transport tcp
no vad
dial-peer voice 90010 pots
description Outbound 10 Digit Local - PRI 0/0:23
destination-pattern 9619[2-9]......
forward-digits 10
dial-peer voice 90011 pots
description Outbound 11 Digit LD - PRI 0/0:23
destination-pattern 91[2-9]..[2-9]......
forward-digits 11
dial-peer voice 9009911 pots
description Outbound 911 - PRI 0/0:23
destination-pattern 9911
forward-digits 3
dial-peer voice 900011 pots
description Outbound International - PRI 0/0:23
destination-pattern 9011T
prefix 011
dial-peer voice 910410 pots
description Outbound 10 Digit Local - FXO 1/0/0
preference 2
forward-digits 10
dial-peer voice 910510 pots
description Outbound 10 Digit Local - FXO 1/0/1
preference 2
forward-digits 10
dial-peer voice 910411 pots
description Outbound 11 Digit LD - FXO 1/0/0
preference 2
forward-digits 11
dial-peer voice 910511 pots
description Outbound 11 Digit LD - FXO 1/0/1
preference 2
forward-digits 11
dial-peer voice 91049911 pots
description Outbound 911 - FXO 1/0/0
preference 2
forward-digits 3
dial-peer voice 91059911 pots
description Outbound 911 - FXO 1/0/1
preference 2
forward-digits 3
dial-peer voice 2021 voip
preference 1
destination-pattern .T
progress_ind setup enable 3
voice-class codec 1
voice-class h323 1
session target ipv4:10.110.20.21
no vad
dial-peer voice 2022 voip
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:10.110.20.22
no vad
dial-peer voice 2020 voip
preference 3
voice-class codec 1
voice-class h323 1
session target ipv4:10.110.20.20
dial-peer voice 99991 pots
preference 1
destination-pattern 9858[2-9]......
forward-digits 10
dial-peer voice 99992 pots
preference 1
destination-pattern 9760[2-9]......
forward-digits 10
dial-peer voice 99993 pots
description Outbound 7 Digit Local - PRI 0/0:23
preference 1
destination-pattern 9.......
forward-digits 7
call-manager-fallback
secondary-dialtone 9
max-conferences 4 gain -6
transfer-system local-consult
limit-dn 7940 1
limit-dn 7960 4
ip source-address 10.34.20.1 port 2000
max-ephones 24
max-dn 96
multicast moh 239.1.1.1 port 16384 route 10.34.20.1 10.34.5.1
end
asandborgh
Level 4
Level 4
HTH,
Art
Thanks for the input. Had the local technician place attach a loopback plug and plan to do some testing with the Telco now.  I'll update shortly.
Art - had the local tech buy a loopback plug.  Attached it to the wall biscuit and telco saw good loopback.   Then attached the loopback to T1 port on router and my physical layer finally went active on show isdn status output.  Thus - it was the patch cable.  We assumed we could use a standard straight - through patch cable and we were WRONG.  Whoever extended the circuit from the demarc to our telco closet patched the biscuit in a way that would not allow us physical connectivity.
Thanks for your input.
Amir
Hppy to help.
Cheers!
Art
