11-06-2012 09:03 PM - edited 03-16-2019 02:03 PM
Hi all,
I am buying a 2811 router with pvdm-32 and vwic-1mft-e1 card. I just need to know that can i use e1 card (for voice not data) directly in the vic slots or do i need nm module for that ?
kindly tell me
Solved! Go to Solution.
11-06-2012 09:56 PM
Correct.
Before you do that setup isdn switch-type globally and network-clock-participate.
Chris
11-06-2012 09:11 PM
Yes you can.
11-06-2012 09:50 PM
Sir i just need to confirm that it will work for voice only right ?
also, what command do i need to issue to make sure it will work for voice ? shall i use pri-group command will that be sufficient to check ?
11-06-2012 09:56 PM
Correct.
Chris
11-06-2012 10:24 PM
Thanks alot sir
