07-14-2014 12:35 AM - edited 03-16-2019 11:23 PM
Dear all
I have Product Authorization Key For 2901 i provide a file.lic from cisco portal but after that I realized that the file is corrupted i made mistake i used Product Name instead PID after that i try to use the rehost on portal cisco also i got the Device Credentials and import that at portal but But at the end I got an error
Solved! Go to Solution.
07-14-2014 06:12 AM
Open a case with the license team.
Just email the information to licensing@cisco.com
They should be able to rehost or fix your mistake and send you back the correct license
07-14-2014 06:12 AM
