02-14-2019 09:29 AM - edited 03-17-2019 02:07 PM
I have a 2911 running the latest CUCME. I have a voice translation rule setup to route all incoming calls to the IVR. The inbound calls just ring forever. Even if I switch the translation rule to an internal extension it won't ring the phone. I've randomly gotten it to work without changing anything but just calling in repeatedly. Any assistance would be helpful.
Solved! Go to Solution.
03-08-2019 07:10 PM
Issue is resolved.
Problem ended up being SIP ALG enabled on the EdgeRouter Pro we are running. Disabled it and problem went away.
02-14-2019 11:24 AM
Can you be a little more specific by posting part of your configuration (translation rule) and making an example?
You may try to test your translation rule by using the command: test voice translation-rule by following the guidelines from this link: https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/61083-voice-transla-rules.html
george
02-14-2019 11:30 AM - edited 02-14-2019 11:31 AM
Sorry about that. Should have included it in the original post. IVR is at pilot number 3000
Test shows normal:
ATLCANNCME#test voice translation-ru 1 19028650158
Matched with rule 1
Original number: 19028650158 Translated number: 3000
Original number type: none Translated number type: none
Original number plan: none Translated number plan: none
CONFIG:
Using 8126 out of 262136 bytes
! Last configuration change at 13:18:54 ATL Thu Feb 14 2019
! NVRAM config last updated at 13:18:55 ATL Thu Feb 14 2019
version 15.7
hostname ATLCANNCME
boot-start-marker
boot system flash0:c2900-universalk9-mz.SPA.157-3.M3.bin
boot-end-marker
enable secret
enable password
no aaa new-model
clock timezone ATL -4 0
ip cef
no ipv6 cef
crypto pki trustpoint TP-self-signed-3608125273
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3608125273
revocation-check none
rsakeypair TP-self-signed-3608125273
crypto pki certificate chain TP-self-signed-3608125273
certificate self-signed 01 nvram:IOS-Self-Sig#2.cer
voice-card 0
voice service voip
ip address trusted list
ipv4 96.125.135.20
ipv4 208.89.128.80
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 600 min 60
g729 annexb-all
voice register global
mode cme
source-address 192.168.4.5 port 5060
timeouts interdigit 2
max-dn 200
max-pool 42
load 8841 sip88xx.11-1-2MSR1-1
timezone 14
voicemail 2000
tftp-path flash:
file text
create profile sync 0001757803034122
network-locale CA
auto-register
voice register dn 1
number 1000
call-forward b2bua busy 2000
call-forward b2bua noan 2000 timeout 20
allow watch
name Christine Halef
shared-line
label Christine Halef
mwi
voice register dn 2
number 1001
allow watch
name Office 220 - Desk 1
label Office 220 - Desk 1
mwi
voice register dn 3
number 1002
name Office 220 - Desk 2
label Office 220 - Desk 2
voice register dn 4
number 1003
name GMR 222
label GMR 222
voice register dn 5
number 1004
name FMO - Desk 1
label FMO - Desk 1
voice register dn 6
number 1005
name FMO - Desk 2
label FMO - Desk 2
voice register dn 7
number 1006
name Admin
label Admin
voice register template 1
voice register pool 1
busy-trigger-per-button 2
id mac 00AA.6E33.36D1
type 8841
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
username cisco password cisco
codec g711ulaw
conference admin
privacy off
voice register pool 2
id mac 00AA.6E33.3918
type 8841
number 1 dn 2
presence call-list
dtmf-relay rtp-nte
username cisco2 password cisco
codec g711ulaw
voice register pool 3
id mac 00AA.6E33.330A
type 8841
number 1 dn 3
presence call-list
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 4
id mac 00AA.6E33.36FF
type 8841
number 1 dn 7
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 5
id mac 00AA.6E32.B7C4
type 8841
number 1 dn 5
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 6
id mac 00AA.6E33.3845
type 8841
number 1 dn 6
dtmf-relay rtp-nte
codec g711ulaw
voice register pool 7
id mac AC44.F211.B8C2
type 8831
number 1 dn 4
dtmf-relay rtp-nte
username cisco3 password cisco
voice translation-rule 1
rule 1 /19028650158/ /3000/
voice translation-rule 2
rule 1 /^1.../ /19028650158/
voice translation-profile Inbound
translate called 1
voice translation-profile Outbound
translate calling 2
vxml logging-tag
license udi pid CISCO2901/K9 sn FTX1536832B
hw-module ism 0
hw-module pvdm 0/0
file privilege 0
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.4.5 255.255.255.0
interface ISM0/0
ip address 172.17.0.1 255.255.255.252
service-module ip address 172.17.0.2 255.255.255.252
!Application: CUE Running on ISM
service-module ip default-gateway 172.17.0.1
interface GigabitEthernet0/1
ip address dhcp
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
no ip address
shutdown
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:CME-GUI-12.0
ip route 10.0.3.0 255.255.255.0 192.168.4.1
ip route 172.16.0.2 255.255.255.255 ISM0/0
ip route 172.17.0.2 255.255.255.255 ISM0/0
ip route 192.168.5.0 255.255.255.0 192.168.4.1
ipv6 ioam timestamp
snmp-server host 45.2.253.149 public snmp
tftp-server flash0:boot1288xx.BE-01-007M.sbn
tftp-server flash0:fbi88xx.BE-01-010M.sbn
tftp-server flash0:kern88xx.11-1-2MSR1-1.sbn
tftp-server flash0:kern288xx.11-1-2MSR1-1.sbn
tftp-server flash0:m0patch288xx.BE-01-001M.sbn
tftp-server flash0:rootfs88xx.11-1-2MSR1-1.sbn
tftp-server flash0:rootfs288xx.11-1-2MSR1-1.sbn
tftp-server flash0:sb288xx.BE-01-025M.sbn
tftp-server flash0:sb2288xx.BE-01-012M.sbn
tftp-server flash0:sip88xx.11-1-2MSR1-1.loads
tftp-server flash0:ssb288xx.BE-01-005M.sbn
tftp-server flash0:vc488xx.11-1-2MSR1-1.sbn
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 2000 voip
destination-pattern 2000
session protocol sipv2
session target ipv4:172.17.0.2
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 3000 voip
destination-pattern 3000
codec g711ulaw
no vad
dial-peer voice 1 voip
description Outbound
translation-profile outgoing Outbound
destination-pattern .T
session target sip-server
session transport udp
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2 voip
description Inbound
translation-profile incoming Inbound
incoming called-number 19028650158
dtmf-relay rtp-nte
codec g711ulaw
no vad
presence
presence call-list
max-subscription 200
sip-ua
credentials number ******* username ******* password 7 ****** realm ******
no remote-party-id
retry invite 2
retry register 10
timers connect 100
timers keepalive down 90
timers keepalive active 90
registrar dns:***** expires 120
sip-server dns:*****
host-registrar
presence enable
gatekeeper
shutdown
telephony-service
authentication credential voicemail voicemail
max-ephones 42
max-dn 200
url services http://172.16.0.2/voiceview/common/login.do
url authentication http://172.16.0.1/CCMCIP/authenticate.asp
cnf-file location flash:
voicemail 2000
max-conferences 8 gain -6
moh enable-g711 "music-on-hold.au"
web admin system name voicemail password voicemail
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Dec 21 2018 15:00:01
ephone-dn 1
number 8000....
mwi on
ephone-dn 2
number 8001....
mwi off
vstack
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
line vty 0 4
password
login
transport input all
scheduler allocate 20000 1000
ntp update-calendar
ntp peer time.google.com
end
02-14-2019 11:42 AM
Can you confirm that you are able to dial 3000 from any internal phone, just to make sure that the IVR is reachable from your end?
George
02-14-2019 11:43 AM
Yes works fine internally.
02-14-2019 11:58 AM
Can you post the "debug ccsip message"?
02-14-2019 04:01 PM
Sorry for the delay. Here it is:
Feb 14 23:59:41.614: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:19028650158@10.0.1.2:5060 SIP/2.0
Via: SIP/2.0/UDP 208.89.128.80:5060;branch=z9hG4bKvpireb30cgkucddbo100.1
From: <sip:9028172323@208.89.128.80:5060;user=phone>;tag=SDs5src01-1938106352-1550188780844-
To: "AtlantiCann ."<sip:19028650158@iristel.net:65331>
Call-ID: SDs5src01-3ecb47a05fa8bdfccae65f55915fa5a3-gem2or2
CSeq: 926535319 INVITE
Contact: <sip:9028172323@208.89.128.80:5060;transport=udp>
Supported: 100rel
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY,UPDATE
Recv-Info: x-broadworks-client-session-info
X-BroadWorks-Correlation-Info: cc3c83c9-9c8b-4fd5-8631-a4033819e70e
Accept: application/btbc-session-info,application/media_control+xml,application/sdp,multipart/mixed
Max-Forwards: 39
Content-Type: application/sdp
Content-Length: 170
v=0
o=BroadWorks 47547699 1 IN IP4 208.89.128.80
s=-
c=IN IP4 208.89.128.80
t=0 0
m=audio 26376 RTP/AVP 0 8 2 18 101
a=rtpmap:101 telephone-event/8000
a=ptime:20
Feb 14 23:59:41.626: //2481/6DB8AA5082D0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 14 Feb 2019 23:59:41 GMT
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.7.3.M3
Session-ID: 00000000000000000000000000000000;remote=4c523a01d4935688801e39687db1dc49
Content-Length: 0
Feb 14 23:59:41.626: //2482/6DB8AA5082D0/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:3000@172.17.0.2:5060 SIP/2.0
Via: SIP/2.0/UDP 172.17.0.1:5060;branch=z9hG4bK76F1825
From: <sip:9028172323@sbc1.iristel.net>;tag=17C8EC0-1A4
To: <sip:3000@172.17.0.2>
Call-ID: 6DB9E2A0-2FEB11E9-82D6BC94-EA7AF038@172.17.0.1
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 1840818768-0803934697-2194717844-3933925432
User-Agent: Cisco-SIPGateway/IOS-15.7.3.M3
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1550188781
Contact: <sip:9028172323@172.17.0.1:5060>
Call-Info: <sip:172.17.0.1:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Max-Forwards: 38
Session-ID: 4c523a01d4935688801e39687db1dc49;remote=00000000000000000000000000000000
Content-Disposition: session;handling=required
Content-Length: 184
v=0
o=CiscoSystemsSIP-GW-UserAgent 374 1913 IN IP4 172.17.0.1
s=SIP Call
c=IN IP4 172.17.0.1
t=0 0
m=audio 16430 RTP/AVP 0
c=IN IP4 172.17.0.1
a=rtpmap:0 PCMU/8000
a=ptime:20
Feb 14 23:59:42.346: //2482/6DB8AA5082D0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
Feb 14 23:59:42.562: //2482/6DB8AA5082D0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:3000@172.17.0.2>;tag=ds7f87e8b9
CSeq: 101 INVITE
Content-Length: 0
Contact: <sip:3000@172.17.0.2:5060;transport=udp>
Allow: INVITE, BYE, CANCEL, ACK, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: 6DB9E2A0-2FEB11E9-82D6BC94-EA7AF038@172.17.0.1
Feb 14 23:59:42.566: //2482/6DB8AA5082D0/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 127
Call-Info: <sip:172.17.0.2:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
v=0
o=CUE 7194321 2 IN IP4 172.17.0.2
s=SIP Call
c=IN IP4 172.17.0.2
t=0 0
m=audio 20892 RTP/AVP 0
Received:
SIP/2.0 200 Ok
CSeq: 101 INVITE
Content-Length: 127
v=0
s=SIP Call
c=IN IP4 172.17.0.2
t=0 0
Feb 14 23:59:42.598: //2482/6DB8AA5082D0/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:3000@172.17.0.2:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 172.17.0.1:5060;branch=z9hG4bK77019BE
Max-Forwards: 70
CSeq: 101 ACK
Session-ID: 4c523a01d4935688801e39687db1dc49;remote=3723bab1583a572aa757fa36b4e01880
Content-Length: 0
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Feb 14 23:59:42.602: //2481/6DB8AA5082D0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: "AtlantiCann ."<sip:19028650158@iristel.net:65331>;tag=17C9290-24E7
Require: 100rel
RSeq: 1540
Contact: <sip:19028650158@10.0.1.2:5060>
Session-ID: 3723bab1583a572aa757fa36b4e01880;remote=4c523a01d4935688801e39687db1dc49
Content-Length: 0
Feb 14 23:59:43.334: //2481/6DB8AA5082D0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Require: 100rel
RSeq: 1540
Content-Length: 0
Feb 14 23:59:44.098: //2481/6DB8AA5082D0/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Require: 100rel
RSeq: 1540
Content-Length: 0
02-20-2019 10:56 AM
Any ideas?
02-21-2019 02:02 AM
Can you post your CUE config as well?
02-21-2019 04:25 PM
Sure can:
clock timezone America/Halifax
hostname ATLCANNCUE
line console
system language preferred "en_US"
software download server url "ftp://127.0.0.1/ftp" credentials hidden "6u/dKTN/hsEuSAEfw40XlF2eFHnZfyUTSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
site name local
phone-authentication credentials hidden "drsG4RYdBv7YJzZdkFqAGA55cpYFhifeSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
site-hostname 172.17.0.1
web credentials hidden "drsG4RYdBv7YJzZdkFqAGA55cpYFhifeSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
end site
license agent max-sessions 9
privilege ViewPrivateList create
privilege ManagePublicList create
privilege ManagePrompts create
privilege broadcast create
privilege manage-users create
privilege ViewRealTimeReports create
privilege vm-imap create
privilege local-broadcast create
privilege manage-passwords create
privilege ViewHistoricalReports create
groupname Broadcasters create
username admin create
privilege ViewPrivateList description "Privilege to view private list"
privilege ManagePublicList description "Privilege to manage public lists"
privilege ManagePrompts description "Privilege to create, modify, or delete system prompts"
privilege broadcast description "Privilege to send local or remote broadcast messages"
privilege manage-users description "Privilege to create, modify, and delete users and groups"
privilege ViewRealTimeReports description "Privilege to view realtime reports"
privilege vm-imap description "Privilege to manage personal voicemail via IMAP client"
privilege local-broadcast description "Privilege to send local broadcast messages"
privilege manage-passwords description "Privilege to reset user passwords"
privilege ViewHistoricalReports description "Privilege to view historical reports"
privilege ViewPrivateList operation voicemail.lists.private.view
privilege ManagePublicList operation voicemail.lists.public
privilege ManagePublicList operation system.debug
privilege ManagePrompts operation system.debug
privilege ManagePrompts operation prompt.modify
privilege broadcast operation broadcast.local
privilege broadcast operation broadcast.remote
privilege broadcast operation system.debug
privilege manage-users operation group.configuration
privilege manage-users operation user.notification
privilege manage-users operation user.mailbox
privilege manage-users operation user.password
privilege manage-users operation user.remote
privilege manage-users operation system.debug
privilege manage-users operation user.pin
privilege manage-users operation user.configuration
privilege ViewRealTimeReports operation report.realtime
privilege vm-imap operation voicemail.imap.user
privilege local-broadcast operation broadcast.local
privilege local-broadcast operation system.debug
privilege manage-passwords operation user.password
privilege manage-passwords operation system.debug
privilege manage-passwords operation user.pin
privilege ViewHistoricalReports operation report.historical.view
groupname Administrators member admin
groupname Broadcasters privilege broadcast
restriction msg-notification create
restriction msg-notification min-digits 1
restriction msg-notification max-digits 30
restriction msg-notification dial-string preference 1 pattern * allowed
backup server url "ftp://127.0.0.1/ftp" credentials hidden "EWlTygcMhYmjazXhE/VNXHCkplVV4KjescbDaLa4fl4WLSPFvv1rWUnfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
calendar biz-schedule systemschedule
open day 1 from 00:00 to 24:00
open day 2 from 00:00 to 24:00
open day 3 from 00:00 to 24:00
open day 4 from 00:00 to 24:00
open day 5 from 00:00 to 24:00
open day 6 from 00:00 to 24:00
open day 7 from 00:00 to 24:00
end schedule
ccn application aa ivr
description "aa"
enabled
maxsessions 6
script "aa.aef"
parameter "dialByExtnAnytime" "true"
parameter "busOpenPrompt" "AABusinessOpen.wav"
parameter "dialByExtnAnytimeInputLength" "4"
parameter "operExtn" ""
parameter "welcomePrompt" "AAWelcome.wav"
parameter "disconnectAfterMenu" "false"
parameter "dialByFirstName" "true"
parameter "busClosedPrompt" "AABusinessClosed.wav"
parameter "allowExternalTransfers" "false"
parameter "holidayPrompt" "AAHolidayPrompt.wav"
parameter "businessSchedule" "systemschedule"
parameter "MaxRetry" "3"
end application
ccn application autoattendant aa
description "autoattendant"
enabled
maxsessions 10
script "aa.aef"
parameter "dialByExtnAnytime" "false"
parameter "dialByFirstName" "false"
end application
ccn application ciscomwiapplication aa
description "ciscomwiapplication"
enabled
maxsessions 10
script "setmwi.aef"
parameter "CallControlGroupID" "0"
parameter "strMWI_OFF_DN" "8001"
parameter "strMWI_ON_DN" "8000"
end application
ccn application msgnotification aa
description "msgnotification"
enabled
maxsessions 10
script "msgnotify.aef"
parameter "logoutUri" "http://localhost/voicemail/vxmlscripts/mbxLogout.jsp"
parameter "DelayBeforeSendDTMF" "1"
end application
ccn application promptmgmt aa
description "promptmgmt"
enabled
maxsessions 1
script "promptmgmt.aef"
parameter "appManagementScript" ""
end application
ccn application voicemail aa
description "voicemail"
enabled
maxsessions 10
script "voicebrowser.aef"
parameter "uri" "http://localhost/voicemail/vxmlscripts/login.vxml"
end application
ccn engine
end engine
ccn reporting historical
database local
description "se-172-17-0-2"
end reporting
ccn subsystem email
end subsystem
ccn subsystem fax
end subsystem
ccn subsystem sip
gateway address "172.17.0.1"
end subsystem
ccn trigger http urlname msgnotifytrg
application "msgnotification"
enabled
maxsessions 2
end trigger
ccn trigger http urlname mwiapp
application "ciscomwiapplication"
enabled
maxsessions 1
end trigger
ccn trigger sip phonenumber 2000
application "voicemail"
enabled
maxsessions 10
end trigger
ccn trigger sip phonenumber 3000
application "aa"
enabled
maxsessions 6
end trigger
service phone-authentication
end phone-authentication
service voiceview
enable
end voiceview
voicemail callerid
voicemail broadcast recording time 300
voicemail default messagesize 240
voicemail notification restriction msg-notification
end
02-25-2019 01:23 AM
I believe CUE is fine and this is a routing issue in CME. I don't see how you are getting to the outside as I don't see a default route to your ITSP. Also, there is no DHCP pool on CME to verify what the phones are using as a default GW. Maybe a little clarification from your side about how the calls are coming in and what GW phones are using would help narrow it down a little bit.
02-27-2019 07:08 AM
Ok so the CME Router is connected to a Ubiqiuti EdgeRouter. It pulls an IP from the EdgeRouter which gives it access to the outside. The Phone are also pulling IPs from the EdgeRouter and communicating to the CME Router on its second port connected to a 48 Port Switch.
Configured like this:
EdgeRouter -> Cisco Router -> 48 Port Switch -> Phones
The connection between the EdgeRouter and Cisco Router is NATed
02-28-2019 04:15 AM
That explains why we don't see all SIP messages in your debug.
I would do things differently. For example, you can:
- Move DHCP for phones to CME, you would need a separte VLAN (in this case 20)
ip dhcp excluded-address 192.168.4.1 192.168.4.20
ip dhcp pool voice
network 192.168.4.0 255.255.255.0
default-router 192.168.4.5
option 150 ip 192.168.4.5
Try to configure your CUE interface this way:
interface ISM0/0
ip unnumbered GigabitEthernet0/0.20
service-module ip address 192.168.4.6 255.255.255.0
service-module ip default-gateway 192.168.4.5
ip route 192.168.4.6 255.255.255.255 ISM0/0
Hope this helps!
03-08-2019 07:10 PM
Issue is resolved.
