2911 VG- fails to call mobile num for one provider
jaheshkhan
Level 5
Level 5
The customer is using a Cisco 2911 Voice Gateway configured with CME and connected via a SIP trunk from the ISP.
There have been no recent configuration changes on the voice gateway; however, the customer is currently experiencing issues with outgoing mobile calls as described below:
Firmware: c2900-universalk9-mz.SPA.157-3.M8.bin
Service Type: SIP Trunk
Issue Details:
  • Outgoing calls to Mobile Service Provider 1: Fail consistently — calls drop immediately after dialing.
  • Outgoing calls to Mobile Service Provider 2: Work most of the time, but occasionally drop before ringing.
  • Incoming calls: Working fine.
  • SIP Trunk: Provided by Mobile Service Provider 1.
A technician from Mobile Service Provider 1 tested outgoing calls using their softphone and confirmed that calls work correctly from their side. They concluded that the issue lies within the Cisco Voice Gateway.
However, it appears that this issue may be caused by parameter or signaling changes on the service provider’s side, which have not been disclosed. When tested through the provider’s ONT device or softphone, calls work normally, indicating a potential SIP interoperability or header mismatch issue.
Similar behavior has been observed at other customer sites using Cisco Voice Gateways, which further supports the possibility of a provider-side SIP parameter change.
ryabenne
You will need to get "debug ccapi inout" and "debug ccsip message" traces from the gateway to determine what might be causing the issue.
Ryan
Please share with us the "debug ccsip messages" and "debug voice ccapi input" so that we can provide insights on what we find when your gateway processes the calls. It would also be helpful if you could share the CME configuration (make sure to remove or hide any confidential information from the show run).
Response Signature
