2911GW, mgcp and Fax issue.
Hi everyone.
I just have installed a new branch for a costumer that include a 2911 with E1 primary for external calls and registered to a CUCM using a mgcp.
So, The CUCM have sip trunks connected to a Right Fax application. primary-> mgcpGw--->cucm sip--->right fax
The problem is the fax have error at the midle of the recepcion and many of them appear cut off. We have cheked send the fax to fax machine (instead of right fax) using ATAs and we have the same problem.  primary-->mgcpGW-->cucm-->ATA---Fax machine.
But depende of the fax machine which is sending the Fax, some works always others never.
The CUCM is 7.1. and this is the mgcp configuration.
SANPOR_2921_1#show run | s mgcp
pri-group timeslots 1-31 service mgcp
ccm-manager mgcp
mgcp
mgcp call-agent 168.124.50.12 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp package-capability srtp-package
mgcp package-capability fm-package
mgcp default-package fxr-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp validate call-agent source-ipaddr
mgcp fax rate 14400
mgcp fax t38 ecm
mgcp fax t38 ls_redundancy 2
mgcp fax t38 hs_redundancy 2
mgcp fax t38 gateway force
mgcp profile default
IOS C2900-UNIVERSALK9-M, Version 15.1(4)M3,
We use this configuration in another branchs and it works fine.
Any ideas?
Thank you for avance
Best Regards.
28 Replies 28
Without T38 the fax to  rightfax doesn't work
Here you have the traces.
physical fax called number
3589499
3589419
3589679
4220110
Right fax to right fax.
3589409
3589629
Did the physical fax work?
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts
Waldo, Well Glad thats working..Atleast we are making progress.
Looking at tha trace I can see that the fax to right fax is not using the correct codec. Its using G729..
+++Trace for rightfax++++
Jun 22 10:26:23.982: MGCP Packet sent to 168.124.50.12:2427--->
200 152213 OK
I: 10
v=0
c=IN IP4 7.48.123.2
m=audio 30610 RTP/SAVP 18 100
a=rtpmap:18 G.729/8000
a=fmtp:18 annexb=no
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
+++This is thetrace for working fax+++Its using G711u
Jun 22 10:29:51.666: MGCP Packet sent to 168.124.50.12:2427--->
200 152357 OK
I: 1D
v=0
c=IN IP4 7.48.123.2
m=audio 23380 RTP/SAVP 0 100
a=fmtp:100 192-194
NB: That the mline= media attribute line with RTP/AVP profile numbers as follows: 0=G711u and 100=modem-passthorugh
So calls to right fax need to use G711ulaw because the mgcp config for modem -passthrough is set to use G711u.
This config: mgcp modem pass-through voip mode nse (uses G711ulaw as the default codec)
Really?
I Can't beliebe I have checked this many times.
Let me check again.
Yes, the regions between the gateway and sip trunks are in G711
Why the gw would be sending the fax in g729?
edit: Use mgcp modem passthrough  codec g711alaw will fix something? We use alaw here in europe.
thank you
Waldo,
The call to 3589629 used the correct codec. But it failed too. This has to do with the configuration on right-fax. This is because after the call was setup, there was no fax switch over. This may be beacuse right fax is configured to use T.38. ( i am not very familiar with right-fax) So in that case it looks like right fax can only do T.38. We will have to re-configure your gateway for T.38.
Did you setup right-fax? what fax protocol did you use..Are you willing to try and re-configure for T.38?
No sorry we dind't cofigure Right-Fax. I can't access to it. Just to check if they recive the faxes.
And for T38,  is my initial configuration correct?
Thank for the help
Ok...Lets switch back to T.38 then.
On VG204 and MGCP gateway please configure...
no mgcp modem pass-through voip mode nse
no mgcp fax t38 inhibit
mgcp fax t38 nsf 000000
Please do test calls and send the ff:
Debug isdn q931
debug mgcp packet
debug voip vtsp all
debug fax relay t30 all-level-1
The righ-fax donesn't work either with t38.... strange. The fax make a connexion but don send anything I attach the logs. Whit the initial configuration unless works with cuts.
This is the currently configuration of the gateway
ccm-manager fallback-mgcp
ccm-manager mgcp
mgcp
mgcp dtmf-relay voip codec all mode out-of-band
mgcp sdp simple
mgcp rtp payload-type g726r16 static
This is the currently configuratoin of the VG
mgcp
mgcp sdp simple
service mgcpapp
service mgcpapp
service mgcpapp
service mgcpapp
Please remove these two commands
Test again while I look at the logs
From the trace..
200 157884 OK
I: 80
v=0
c=IN IP4 7.48.123.2
m=audio 17418 RTP/AVP 0 100
a=fmtp:100 192-194,200-202
a=X-sqn:0
a=X-cap: 1 audio RTP/AVP 100
a=X-cpar: a=rtpmap:100 X-NSE/8000
a=X-cpar: a=fmtp:100 192-194,200-202
a=X-cap: 2 image udptl t38
a=fmtp:100 192-194,200-202 (pt=100, event type=192-194) This implies that gateway still has modem pass-through enabled. We need to disable it. If you have removed it then we may need to restart MGCP.
T.38 wont work with Modem pass-through
Yes you right, I have reseted the mgcp process and now I can send fax  to right-fax. But Now I have to check if the costumer can send every  fax corretly as I from my fax I did'n have problems before.
Thank you very  for your help.
T38 I looks better for the right-fax. of 15 faxes, fail 3.
But the phisical faxes don't work properly. they told  me faxes from spain to portugal (branch country) works fine but from  portugal to portugal not. It is a nightmare .
I can't get traces anymore because I dont have access to the GW.
this is the final configuration
VG1  VG2
mgcp
mgcp sdp simple
mgcp fax t38 ecm
service mgcpapp
service mgcpapp
service mgcpapp
service mgcpapp
GW1, GW 2
mgcp sdp simple
mgcp fax rate 14400
mgcp fax t38 ecm
There are 2 CCIEs in my company and any of them culdn't help me today. Unless I wasn't alone
Thanks Aokanlawon
Edit: Sorry, I didn't see remove these comands
I will try tomorrow.
Waldo,
I am glad I could help. In your GW1 and GW2 configuration you have conflicting configuration. You have enabled both nse based T.38 and Standard based T.38. You shouldnt do this because I am not sure your right fax will support nse based. I did suggest to remove those configurations..so configure the ff:
no mgcp fax t38 ecm
no mgcp fax t38 ls_redundancy 2
no mgcp fax t38 hs_redundancy 2
no mgcp fax t38 gateway force..............This is enabling nse based T.38.
remeber to rest mgcp
Also configure this on VG1 and Vg2
no mgcp fax t38 ecm
Please do a test call from
1. Physical fax
send the ff
Debug isdn q931
debug mgcp packet
debug voip vtsp all
2. right-fax
Debug isdn q931
debug mgcp packet
debug voip vtsp all
Hi Again.
Thanks but finaly the problem was fix it. My partner connected to the client and he changed some configuration. Now every fax works. This is the final configuration.
GW
ccm-manager redundant-host 168.124.50.11
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
mgcp
mgcp ip qos dscp cs3 signaling
mgcp playout fax 700
mgcp sdp simple
mgcp fax rate 14400
mgcp fax t38 ls_redundancy 1
mgcp fax t38 hs_redundancy 1
mgcp fax-relay ans-disable
VG
ccm-manager mgcp
ccm-manager sccp local FastEthernet0/0
mgcp
mgcp sdp simple
mgcp fax rate 14400
Thanks .
Regards.
