2921 Not enough DSP resources available PRI
Hello Friends,
I´m programing PRI with 32 channels, but 2921 say 2 extra DSP are required.
Please, any idea?
Router(config)#controller e1 0/0/0
Router(config-controller)#pri-group timeslots 1-31
% Not enough DSP resources available to configure pri-group on controller E1 0/0
/0
% The remaining dsp resources are enough for 0 time slots.
% For current codec complexity, 2 extra 16 channel dsp(s) are required to create
this voice port.
__________________________________________________________________________________________
Router#show voice dsp group all
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 32.1.1
  Max signal/voice channel: 32/32
  Max credits: 480, Voice credits: 480, Video credits: 0
  num_of_sig_chnls_allocated: 6
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 96, reserved credits: 0
    Signaling channels allocated: 6
    Voice channels allocated: 0
    Credits used (rounded-up): 0
  Group: FLEX_GROUP_CONF, complexity: CONFERENCE
    Shared credits: 0, reserved credits: 384
    Codec: CONF_G729, maximum participants: 8
    Sessions per dsp: 5
  Slot: 0
  Device idx: 0
  PVDM Slot: 0
  Dsp Type: SP2600
DSP groups on slot 1:
This command is not applicable to slot 1
  0 DSP resource allocation failure
Your FXO cards and conference profiles are taking up all the DSPs.
Chris
5 Replies 5
Chris Deren
Post your config and "sh diag", also have you seen these great docs from Deji:
https://supportforums.cisco.com/docs/DOC-29164
https://supportforums.cisco.com/docs/DOC-29151
Chris
Chris,
Router#sh run
Building configuration...
Current configuration : 3639 bytes
! Last configuration change at 16:38:58 UTC Fri May 24 2013
version 15.2
hostname Router
boot-start-marker
boot-end-marker
card type e1 0 0
no aaa new-model
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip cef
no ipv6 cef
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice class codec 100
codec preference 1 g729r8
codec preference 2 g711ulaw
codec preference 3 g711alaw
voice class h323 200
  h225 timeout tcp establish 3
  h225 timeout setup 3
license udi pid CISCO2921/K9 sn FTX1712AJLJ
license accept end user agreement
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
framing NO-CRC4
controller E1 0/0/1
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
mgcp profile default
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
associate application SCCP
dial-peer voice 1000 pots
description Llamadas PSTN
destination-pattern 92[2-9]......
direct-inward-dial
forward-digits 8
dial-peer voice 1001 pots
description Llamadas Emergencia
destination-pattern 91[34].
direct-inward-dial
forward-digits 3
dial-peer voice 1002 pots
description Llamadas Informaciones
destination-pattern 910.
direct-inward-dial
forward-digits 3
dial-peer voice 1003 pots
description Llamadas 600
destination-pattern 9600.......
direct-inward-dial
forward-digits 10
dial-peer voice 1004 pots
description Llamadas 800
destination-pattern 9800......
direct-inward-dial
forward-digits 9
dial-peer voice 1005 pots
description Llamadas LDN
destination-pattern 9188T
direct-inward-dial
prefix 188
dial-peer voice 1006 pots
description Llamadas LDI
destination-pattern 91880T
direct-inward-d
prefix 1880
dial-peer voice 1007 pots
description Llamadas Celulares
destination-pattern 909[5-9].......
direct-inward-dial
forward-digits 10
dial-peer voice 5000 voip
description Anexos Internos
destination-pattern ....
session target ipv4:10.200.1.5
incoming called-number .T
voice-class codec 100
voice-class h323 200
dtmf-relay cisco-rtp h245-alphanumeric
ip qos dscp cs5 media
gatekeeper
shutdown
call-manager-fallback
max-conferences 4 gain -6
transfer-system full-consult
ip source-address 10.200.10.2 port 2000
max-ephones 100
max-dn 200
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Router#
Router#
Router#sh diag
Slot 0:
        C2921 Mother board 3GE, integrated VPN and 4W Port adapter, 11 ports
        Port adapter is analyzed
        Port adapter insertion time 02:36:16 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC17031
        Hardware Revision        : 1.0
        Part Number              : 73-11835-11
        Top Assy. Part Number    : 800-30794-07
        Board Revision           : A0
        Deviation Number         : 130603
        Fab Version              : 03
        Product (FRU) Number     : CISCO2921/K9
        Version Identifier       : V08
        CLEI Code                : CMMHS10ARB
        Processor type           : C2
        Chassis Serial Number    : FTX1712AJLJ
        Chassis MAC Address      : b0fa.eb92.b60
        MAC Address block size   : 80
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 37 30 33 31 47 31 38 40
          0x10: 06 16 41 01 00 82 49 2E 3B 0B C0 46 03 20 00 78
          0x20: 4A 07 42 41 30 88 00 01 FE 2B 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 32 31 2F 4B 39 89 56 30 38 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 48 53 31 30 41 52
          0x50: 42 09 C2 C2 8B 46 54
          0x60: C3 06 B0 FA EB 92 B6 00 43 00 50 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 03 40 01 63 FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Internal Power Supply information
        Top Assy. Part Number    : 341-0226-03
        Deviation Number         : 0
        PCB Serial Number        : QCS1650H2T3
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Version Identifier       : V03
        Product (FRU) Number     : PWR-2921-51-AC
        CLEI Code                : 0000000000
        Board Revision           : A0
          0x00: 04 FF 40 05 E2 DF 45 01 55 00 E2 03 88 00 00 00
          0x10: 00 C1 8B 51 43 53 31 36 35 30 48 32 54 33 03 00
          0x20: 81 00 00 00 00 04 00 89 56 30 33 20 CB 8E 50 57
          0x30: 52 2D 32 39 32 31 2D 35 31 2D 41 43 C6 8A 30 30
          0x40: 30 30 30 30 30 30 30 30 F3 00 59 41 01 22 42 00
          0x50: 05 F8 00 50 01 F4 14 41 02 EE 16 F
          0x60: 04 E2 1A 76 05 DC 1B 91 06 D6 1C 78 07 D0 1D 10
          0x70: 08 CA 1D 9E 09 C4 1E 6D 0A BE 1E A8 0B B8 1F 5E
          0x80: 0D AC 20 FB 0F A0 21 18 11 94 21 64 13 88 21 71
          0x90: 17 70 21 9F 1B 58 21 96 1F 40 21 6D 23 28 21 62
          0xA0: 27 10 21 5A 42 41 30 FF FF FF FF FF FF FF FF FF
        PVDM Slot 0:
        32-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11577-03
        Board Revision           : C0
        Fab Version              : 03
        PCB Serial Number        : FOC170452Z3
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-32
        Version Identifier       : V01
          0x00: 04 FF 40 05 D9 41 01 00 82 49 2D 39 03 42 43 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 37 30 34
          0x20: 35 32 5A 33 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 33 32 20 20 20 20 20 20
          0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
        Hardware Revision        : 0.0
        Top Assy. Part Number    : 800-22629-05
        Board Revision           : C0
        Fab Version              : 04
        PCB Serial Number        : FOC12502VTL
        RMA History              : 00
        Product (FRU) Number     : VWIC2-2MFT-T1/E1
          0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
          0x10: 42 43 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
          0x20: 32 35 30 32 56 54 4C 03 00 81 00 00 00 00 04 00
          0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
          0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
        WIC Slot 1:
        2nd generation - FXO Voice daughter card (4 port)
        Hardware Revision        : 5.0
        Top Assy. Part Number    : 800-21589-02
        Board Revision           : B0
        Deviation Number         : 9-299
        Fab Version              : 04
        PCB Serial Number        : FOC11282R9U
        RMA History              : 00
        Product (FRU) Number     : VIC2-4FXO
        CLEI Code                : CNUIAPRAAA
        EEPROM contents (
          0x00: 04 FF 40 00 4C 41 05 00 C0 46 03 20 00 54 55 02
          0x10: 42 42 30 80 00 09 01 2B 02 04 C1 8B 46 4F 43 31
          0x20: 31 32 38 32 52 39 55 03 00 81 00 00 00 00 04 00
          0x30: CB 89 56 49 43 32 2D 34 46 58 4F 89 56 30 31 20
          0x40: C6 8A 43 4E 55 49 41 50 52 41 41 41 FF FF FF FF
        WIC Slot 2:
        2nd generation - FXO Voice daughter card (2 port)
        Top Assy. Part Number    : 800-21597-01
        Board Revision           : E0
        Deviation Number         : 0-0
        Fab Version              : 04
        PCB Serial Number        : FOC09171Q5V
        RMA History              : 00
          0x00: 04 FF 40 00 4D 41 05 00 C0 46 03 20 00 54 5D 01
          0x10: 42 45 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 30
          0x20: 39 31 37 31 51 35 56 03 00 81 00 00 00 00 04 00
          0x30: 89 56 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
          0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
te to up
!e
!i
!a
!2
contro
Embedded Service Engine 0/0 :
!N
!I
voic
  Total platform memory : 524288K bytes
!e
voice-port 0/
  Total 2nd core memory : 0K bytes
!c
voice-port 0/1
  Start of physical address for 2nd core : 0x80000000
voice-port 0/1/3to up  accept
  Virtual address start of 2nd core memory : 0x0 - 0x0
!t
voice-port 0/2/1 DN 154.1
  2nd core configured disabled
!st
!ce
  L2 cache ways for 2nd core : 0ultriod: 8  w
Router#sh runduct
Building configuration...conference by
Current configuration : 3639 bytes479: %L
c
!e
! Last configuration change at 16:38:58 UTC Fri May 24 2013729r8 at 19:52:26!
codec g729abr
version 15.2
te t
service timestamps debug
no ipv6 cef
!o
!p
multilink bundle-name authenticatedice 1002 potse to upof the
!f
!m
!i
voice-card 0_dsp DN 160.
dspfarmd sta
voice service voipstination-pattern
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback nonedirect-inward-dialfax proto
te to upe
voice class codec 100.479: %LINK
!1
!6
!o
!c
!s
frami
license accept end user agreementcontroller E1 0/0/1
hw-module pvdm 0/0pattern 91880T3 19
!5
!3
!7
redundancy
controller E1 0/0/0
framing NO-CRC4ale_dsp DN 166.1
controller E1 0/0/1
prefi
!1
csdb tcp
d
csdb tcp finwait-time 5lares23 19:55:33.479: %
csdb tcp reassembly max-queue-length 16.6ense State: Not
voice-clas
csdb icmp idle-time 10N
no ip addressper Interface
shutdown
duplex autoN 171.
speed auto
!a
ca
no
no ip address
max-co
shutdown4 gain -6
duplex auto
speed auto
duplex
interface GigabitEthernet0/2sfer-system full-consult: %L
no ip address
shutdown
ip so
duplex auto10.200.10.2
speed autoion 15.0(1r
no ip http server secure-serve
no ip http secure-serverephones 100, integr
control-plane
max-dn 200
voice-port 0/1/0
voice-port 0/1/1PDOWN:
voice-port 0/1/2phone_dsp
voice-port 0/1/3-port
voice-port 0/2/0r
DSP groups on
codec g711ulaw
codec g711alaw
dsp 1:voice
codec g729ar8ate: UP, firmw
codec g729abr855:33.483: %LIN
codec g729r8
codec g729br8
maximum sessions 4gnal/voice channel:
associate application SCCP]......prog
  M
description Llamadas PSTNits: 480, Video credits: 0
te to up :
direct-inward-dial
*May 23 19:55:33.
forward-digits 8N:
dial-peer voice 1001 potsof_sig_chnls_allocated: 6
descriptio
destination-pattern 91[34].nscoding channels allocated:
direct-inward-dial
forward-digits 3
destination
description Llamad
direct-inward-dial slot 1:: %LINK-3-U
forward-digits 10
dial-peer voice 1004 pots is not applicable to slo
description Llamadas 800####
destination-
direct-inward-dialconfig-controller)#
forward-digits 9
!u
Router#s
description Llamadas LDNYS-5-CONFIG_I: Configured
destination-pattern 9188T tel
direct-inward-dial
prefix 188
!c
Router#sh t?
description Llamadas LDIcacs           tarp
direct-inward-d
Router#sh te
telephony-service
session target ipv4:10.200.1.5y-service?
Router#sh
voice-class h323 200not enable
dtmf-relay cisco-rtp h245-alphanumericrect-inward-dial
fo
dial-peer
!i
max-ephones 100
max-dn 200
line con 0
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
login
transport input all
end
Chris
There is also a tool to calculate the needed DSP-ressources:
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Thanks Karsten.
Your information was very usefull...!
