2921 voice gateway dial-peer
bo liu
Level 4
Level 4
i use 2921 as voice gateway
and have two dial-peer :
dial-peer voice 8000 voip
destination-pattern 8...
session protocol sipv2
session target ipv4:10.10.10.21:5060
voice-class codec 1
dtmf-relay cisco-rtp h245-alphanumeric h245-signal rtp-nte sip-kpml sip-notify
no vad
dial-peer voice 8001 voip
preference 1
session target ipv4:10.10.10.210:5060
voice-class codec 1
no vad
so if 10.10.10.21 down the dial-peer 8001 should transfer the call to 10.10.10.210
but....now i shunt down the NIC of 10.10.10.21 ,and debug voice ccapi
the router also send the call to dial-peer 8000
why this and how should i config the GW???
2 Accepted Solutions
Ayodeji Okanlawon
What is the setup? What does the gateway connect to? Can you provide your full scenario..Do you hae any config that checks the status of the dial-peer...
Try this
conf t
monitor probe icmp-ping 10.10.10.21
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
You need to enable monitor probe icm-ping:
1. Under your dial-peer look into the  "*monitor probe icmp-ping* X.X.X.X"
command. If destination does not respond it shuts down that dial-peer.. therefore
failover should be instant.
2. Global config - you can adjust your timers - it will try 6 times, with 3
sec timeout by default
sip-ua
retry invite 3
timers trying 2
Favor calificar todos las respuestas útiles.
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
6 Replies 6
Ayodeji Okanlawon
Try this
conf t
hi aokanlawon
thanks for you reply
e ..the 2921 is UCCE ingress gateway,and connect to CVP,now i deploy two CVP for redundancy
sip-ua
retry invite 3
timers trying 2
Leo,
The timers trying is in ms (so i think 2 is way too short...) Ideally it should be something like this
sip-ua
retry invite 2
timers trying 150
hi leo
in your reply ,the name monitor probe icmp-ping* X.X.X.X is use ICMP? but if my CVP server is runing ,and the Call Server
component is down,can the dial-peer shutdown ?
i another customer use 2821, i'm not config anything ,but the dial-peer can monitor the CVP up or down....
the command is 2900 router new command ?
bo liu
Level 4
Level 4
i find this situation
i configuare the command "preference 1" in dial-peer ,and the two dial-peer can failover
but if the preference 0 dial-peer down ,and a call send in gateway from PSTN,the router will route the call to preference 0 dial-peer , and just route to preference 1 dial-peer about 20S after...
where can i configuare the timer with the preference??
