2N Helios IP force not registered wih CME
STD IN
7 Replies 7
R0g22
What is the "type P600" in here for ? Remove the ID MAC and configure "id device-id-name" instead and see if that helps.
Hi Nipun ,
I just configured as below but it still not registered
voice register pool  2
 id device-id-name test
 number 1 dn 2
 dtmf-relay rtp-nte
 voice-class codec 1
 username Helios_IP password 1234
or
 registration-timer max 720 min 660
 id mac 7C1E.B301.A4BA
 session-transport tcp
 number 1 dn 2
 dtmf-relay sip-notify
 codec g711ulaw
 camera
 video
R0g22
How did you refer "test" on your device ?
you have any clue how to  refer test to 2N helios ?
N.B: connected by the RJ45 Network
R0g22
Not sure, no experience with helios. Was does it have, a web page to configure ? Is there a registrar/registration/sip section ? Add a snapshot.
R0g22
Seems a bit similar to Xlite. The username/password that you have under the pool is incorrect. Correct that and if the phone does not register still, enable the following -
debug ccsip message
debug ccsip error
debug voice register event
debug voice register error
