3 Beep Tones on analog phone on ATA190
Paul Freiberg
Hi all,
we use some analog DECT phones on ATA190. But each call the user hears 3 beep tones (Dutdut Dutdut Dutdut). It sounds similar to some initial fax tones.
Do you know how I can avoid it?
And it occurs just in secure mode.
I found this bug/enhancement which you may be encountering:
"Require to remove background Beep tones in secure mode"
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCva34585
The detail on the bug is pretty limited, there are no known fixed releases.
7 Replies 7
Jonathan Unger
Level 7
Level 7
Hi Paul,
The 3 long tones are normal for secure calls, they indicate that the call is encrypted.
For more info on secure tones, check out the CUCM security guide here:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/security/10_0_1/secugd/CUCM_BK_C68276B4_00_cucm-security-guide-100/CUCM_BK_C68276B4_00_cucm-security-guide-100_chapter_01000.html#CUCM_RF_SA34DE14_00
You can disable the secure tone on the ATA by unchecking the "Protected Device" tickbox under the device in CUCM.
Hi Jonathan,
thanks for your answer. It sounds like the correct answer, the notes at the bottom too.
But "Protected Device" is not checked :(
I did not found any enterprise phone or common phone configuration that overwrite that setting...
A few points:
  1. Do you know if that tickbox has ever been checked for that device in the past?
  2. Can you try resetting the device from CUCM and seeing if that helps?
  3. What is the value of the CUCM service parameter "Play Tone to Indicate Secure/Non-Secure Call Status"?
1. That tickbox was never checked. It is a test device shortly installed.
2. Resetting did not helped.
3. The parameter is set to false.
Hmmm,
bugs, bugs there are everywhere bugs ;)
It is classified as "Severity:6 Enhancement" and 1.3 was not officially released... that will take a long time :(
Yes exactly, unfortunately if the tones are very disruptive, the device will need to be set back to an insecure mode.
***Please rate helpful responses and mark applicable answers as correct so the rest of the community can benefit.
