30 PSTN Line support question
Dear All;
We have 2911 ISR 2 Router and also we have :
     "EM-HDA-6fxo"          quantity =  2
      EVM-HD-8FXS/DID   quantity  =  1
      VIC2-4fxo                 quantity =  2
my question : is this configuration enough to support 30 analog PSTN line ?
please explain
thanks in advance
Rashed .
paolo bevilacqua
That only makes 20 FXO lines and is not a good solution. SInce it is very complicated and expensive to have so many FXOs in a router, ask telco to give you ISDN PRI instead. They can do that for sure, even if they say that is not possible initially.
paolo bevilacqua
