07-28-2011 07:03 PM - edited 03-16-2019 06:11 AM
We are using Cisco 3560 switches with Cisco 79xx and 69xx series phones connected to them.
Whats the best practice for configuring an interface with a cisco phone connected to it? I'd like some consistency accross the board, are there any commands that can be ommited or should be added.
Current config
interface FastEthernet0/1
switchport access vlan 2
switchport mode access
switchport voice vlan 12
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
priority-queue out
mls qos trust device cisco-phone
mls qos trust dscp
auto qos voip cisco-phone
macro description cisco-phone
spanning-tree portfast
service-policy input AutoQoS-Police-CiscoPhone
Config from another site
interface FastEthernet0/12
switchport access vlan 11
switchport voice vlan 101
mls qos trust dscp
spanning-tree bpduguard enable
Solved! Go to Solution.
07-28-2011 08:07 PM
both can work with out any issue if the voice and data vlans are right
the only difference is the first one is better because it has the priority queue enabled and traffic shaping for queue 1 (PQ) is set to avoid over utilize other queues by voice traffic in conjunction with the inbound policing
i would say first one looks better but second one works as well
07-28-2011 09:13 PM
Hi Brendan,
the priority-queue enable the HW priority queue in the switchport ( traffic in that queeu will be serviced first )
queue-set is the inbound queuing config, you can change some of the ingress queues maping to cos/dscp for example
3560 egress priority queue has queue-id 1
07-28-2011 08:07 PM
07-28-2011 08:54 PM
Cheers for that, I will add srr-queue bandwidth share 10 10 60 20 and srr-queue bandwidth shape 10 0 0 0
What do the following commands do exactly?
priority-queue out
queue-set
07-28-2011 09:13 PM
Hi Brendan,
