03-06-2015 01:24 AM - edited 03-17-2019 02:13 AM
I am trying to do some policing on a 3650 and for some reason, the interface doesn't seem to want to apply my service policy. Here is my config:
class-map match-any ExchangeClass
match vlan 410
policy-map ExchangePolicy
class ExchangeClass
police cir percent 25 conform-action transmit exceed-action drop violate-action drop
I use the command service-policy input ExchangePolicy on the gi1/0/1 interface, I then do a sh run int gi1/0/1 and there is no input service policy shown in the config. Does anybody know why it hasn't applied the service policy? If I use an auto qos input service policy then it seems to apply it.
04-01-2015 07:56 AM
The log will have a reason as to why is was not applied.
I have the same problem on a 3850 have asked this question:
https://supportforums.cisco.com/discussion/12467066/qos-routed-ports-3850
e.g.
Invalid queuing class-map!!! Queuing actions supported only with dscp/cos/qos-group/precedence based classification!!!
04-03-2015 04:52 AM
Hi Mark,
I had something similar on the 3850 when i was looking at 2 rate 3 colour policer. I am not 100% but suspect this is because you maybe only have one rate defined but 3 actions. I.e. if you had a cir, burst rate then think it might work.
Matt
