3725 and VIC-2FX0
atrzonkowski
Hello all
I am working on my first VOIP/UC project and I'm running into some trouble out of the gate.
I have a 3725 router and access to two IOS images:
advipservicesk9-mz.124-25d and ipvoice-mz-124.25d
I've installed a NM-HD-2V card into the 3725 but when I install the VIC-2FX0 I'm running into issues.
Show Diag yields:
WIC Slot 1:
FXO Voice daughter card (2 port)
WIC module not supported/disabled in this slot
Hardware revision 1.1           Board revision N0
Serial number     30246568      Part number    800-02495-01
FRU Part Number     VIC-2FXO=
Test history      0x0           RMA number     00-00-00
Connector type    Wan Module
EEPROM format version 1
EEPROM contents (hex):
   0x20: 01 0D 01 01 01 CD 86 A8 50 09 BF 01 00 00 00 00
   0x30: B8 00 00 00 03 05 21 01 FF FF FF FF FF FF FF FF
This occurs with either IOS image. Any tips or thoughts on why this occuring? Thank you in advance for any help.
paolo bevilacqua
paolo bevilacqua
As the router is telling you, that old module is not supported on the NM.
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a00800ae37f.shtml
Ah, yes, the subtle difference between VIC2-2FXO and VIC-2FXO. I have the wrong hardware =\
Thank you the clarification!
Thank you for the nice rating and good luck!
