3PCC on cisco 7800, 8800 phones
balyu2015
 Hello, collaboration professionals!
 Please, answer to my question. Where is 3PCC firmware for 7800 and 8800 series phones. Can I change firmware for existing 7800/8800 phones with CUCM firmware to 3PCC , and if I can, how to do it?
Thank you.
Found the firmware easily enough, but finding the 3PCC SKU's on CCW seems to be a challenge. . . .
35 Replies 35
Manish Gogna
Its there on cisco.com
https://software.cisco.com/download/release.html?mdfid=286255327&flowid=54174&softwareid=282074288&release=10.3%281.9%29%203rd%20Party&relind=AVAILABLE&rellifecycle=&reltype=latest
https://software.cisco.com/download/release.html?mdfid=286285173&flowid=76722&softwareid=282074288&release=10.3%281.11%29%203rd%20Party&relind=AVAILABLE&rellifecycle=&reltype=latest
Conversion procedure is given in release notes
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7800-series/3pcc/english/release-notes/PA2D_BK_7C8E9902_00_7800-series-3pcc-rn-1031.html
Manish
Hi Manish, thank you for reply.
I had read this manual yet .
I do not find conversion procedure from CUCM to 3PCC in it. I find firmware upgrade procedure (3PCC to 3PCC) and conversion procedure from 3PCC to CUCM. Also I find that caution:
**After you upgrade to the enterprise firmware, you cannot revert to the third-party call control firmware. **
Does it means, what I can't convert firmware from CUCM to 3PCC?
That seems to be the case here as it clearly says that after you upgrade to the enterprise firmware, you cannot revert to the third-party call control firmware.
Manish
Ok, thank you Manish.
So, right answer will be - no, you can't change firmware for existing 7800/8800 phones with CUCM firmware to 3PCC.
That is true, To get 3PCc on an 88XX you need to purchase the proper SKU.
Manish
- Do rate helpful posts -
What's the proper SKU to purchase in order to use the 3PCC firmware?  For example, the CP-8851-K9= only has the 1 SKU
Hi Michael,
I could find one for 8831 (  CP-8831-3PCC-K9= ), you may check with your Cisco Account team for details about the models that you don't find on cisco.com.
Manish
Is the 8831 the only 3PCC model available?   I can't seem to find any other phone models that can be used for 3PCC.
Also, are there any versions of Cisco firmware that are "non" enterprise?
All 7800 and 88x1 have appropriate 3PCC SKUs.
Firmware is on CCO as linked above.
Just as above:
CP-7811-3PCC-K9=
CP-7821-3PCC-K9=
CP-7841-3PCC-K9=
CP-7861-3PCC-K9=
CP-8811-3PCC-K9=
CP-8831-3PCC-K9=
CP-8841-3PCC-K9=
CP-8851-3PCC-K9=
CP-8861-3PCC-K9=
Thank you, I'll keep looking in CCW and elsewhere.
Am I to assume that 3PCC is not available for the 8845 and 8865 as I cant find the SKU?
Will it be available in the future?
Michael,
What we've discovered so far is that any phone model that offers video is NOT supported with 3PCC SKU nor firmware. .. . .
Kevin
