06-08-2018 10:16 AM - edited 03-17-2019 12:59 PM
We have 3PCC CP-88XX phones.
Incoming calls are not resolved to the number stored in the address book (which would show the name) the issue is that LDAP reverse lookup does not work. This is basic functionality (CallerID) I do not understand why this would be a problem.
Solved! Go to Solution.
05-18-2020 06:37 AM
Do as the Cisco employee suggests and upgrade the firmware.
Cisco have already fixed this.
Adam
05-18-2020 07:14 AM
Thanks Adam, that's the first thing I tried, current firmware I have upgraded to is:
sip8845_65.11-3-1MPP-697.loads
Is there another one I can try?
05-18-2020 08:29 AM
I also tried the one recommended by Cisco support by the way:
11.3.1MSR1.3
Same issue, even with the change to
Search Item 3: | Number |
Search Item 3 Filter: | telephoneNumber |
05-18-2020 10:48 AM
Please reach out to support and raise a case. They will share the fixed firmware with you or look into the logs to see if there is any other bug in this area.
