02-14-2012 06:58 AM - edited 03-16-2019 09:35 AM
Dera All,
My customer having Cisco Unified Comm Manager 8.5 and he is welling to purchase a 3rd party billing system integrated with Cisco. his main concern is: he need to define a limit per user in the costs of the calls and once the user exceed the limit he cant issue a call.
could you please advice us which Software can do this?
Thanks and Regards,
02-14-2012 07:10 AM
Unfortunately, there is no such application as the call accounting apps are read only and pull info from CUCM via SFTP/FTP. You can define cost within those applications, but they will never instruct CUCM to reject the call.
HTH,
Chris
10-13-2014 03:48 AM
You can have a look into solution from CommSouth in which PhoneManager is deployed and SIP trunk is configured between CUCM /Phone Manager.
You can reach them on : www.commsouth.in and Email: info@commsouth.com
regds,
aman
02-16-2012 06:10 AM
Sorry as Chris has pointed out call logging / accounting software can only provide reports, what you are describing is more like a AAA service where you can block calls.
You can find certified reporting software here:
Call Logging (Cisco Certified only)
http://developer.cisco.com/web/partner/search?text=call logging&technologyIds=a0G40000000xlnlEAA&subTechnologyIds=a0K40000000eHsEEAU&technologyProductIds=a0I40000000ycykEAA&partnerProductFamilies=Call Accounting and Billing&certified=Yes&onCiscoPriceList=All&portfolioPartner=All
Call Accounting (Cisco Certified only)
We have an option within our call logging software where you can create call alarms based on the CDR's, e.g. cost of call, number of phone lines used reaches a set limit then trigger an alert.
You could use our unlimited display boards to show call information.
Our TIM Plus and TIM Enterprise products have AXL integration so they auto configure the directory based on your UCM configuration, saving you lots of administration time.
Both are Cisco IVT tested so you can be sure that it is compatible, to arrange a free trial go to our Cisco microsite
Overview video:
02-18-2012 12:15 AM
Dear Jamie,
you meen, by using TIM Plus or TIM Professional I can prevent the user from the calls once he exceed the cost/duration limit.
02-21-2012 04:12 AM
You may also consider having a look at CALLTRAK for your Call accounting needs.
Please visit www.calltrak.com.au
CALLTRAK provides call accounting, allocation of additional billing information, call center analysis, line utilisation and many more functions.
Competitive pricing and reliable.
I hope this helps.
Theodore
02-21-2012 06:22 AM
Does CALLTRACK provide ability to reject calls after call limit is reached as was the poster's request? I would be surprised if there is such an application as I dont think CUCM has an API to allow this to happen.
HTH,
Chris
10-10-2014 02:33 PM
Dear lalqatta982011:
We have the solution for you. Our software does exactly what you´re looking for.
Please, go to www.ideasbamboo.com or email me at info@ideasbamboo.com
Thank you.
David.
10-13-2014 04:02 AM
regards,
Prasana
