12-31-2010 05:44 AM - edited 03-16-2019 02:39 AM
Hi!
We have a lot of SCCP Cisco Phones that are working ok, but I need to add some 3rd party SIP Phones.
The registration is ok! But I can't find the wat to do Call-Transfer and Call Pickup!
I couldn't to find any information in CISCO forum, nor www.cisco.com, nor Help pages.
Is it possible? I need some help!
Thanks! This is my first post in the Forum!
Happy new year!!
Solved! Go to Solution.
01-03-2011 11:39 AM
That screenshot does nothing for me. Post the CAP file so I can read the actual SIP messages. Make sure the capture includes an entire call from dial to hang-up.
12-31-2010 10:03 AM
The most common mistake is not configuring a Rerouting CSS on the device configuration within CUCM. CUCM imposes the Rerouting CSS on both the REFER and REPLACES headers.
If that does not solve it, a packet capture showing the SIP dialog between the endpoint and CUCM would be helpful.
01-03-2011 02:35 AM
Hi! Thanks for your reply!
Sorry! My English is poor!
[EDIT] I have found Rerouting CSS, I had already configured that option. That is not my problem. [EDIT]
I have worked a lot with SCCP and I don't have any idea how to configure Call-Pickup adn Call Transfer for 3rd party SIP phones.I don't know if that is possible!
Is there some tutorial that shows how to use these features in 3rd party SIP phones? or may you give me some more help?
Thanks!
01-03-2011 08:02 AM
I cannot find documentation suggesting that Call Pickup will work. While RFC3891 suggests it is possible using the Replaces header, I cannot speak to how CUCM would handle this; I expect not well since the phone would have no way of relaying the pickup group in that header.
Transfer should work though. What is the end point you are using? Cisco is allowing a third-party to provide some limited certification: http://www.tekvizionlabs.com/3rdpartyprograms/sip_verification/
Again, a packet capture showing the SIP dialog would be helpful here.
01-03-2011 09:04 AM
Hi.
I'm trying 2 endpoints:
1 - Polycom Soundpoint IP 320 SIP
2 - IP Video Phone VP-2009
I did a capture and the SIP dialog seems ok
It happens each 30 seconds.
01-03-2011 11:39 AM
01-04-2011 02:17 AM
01-04-2011 07:24 AM
Hi!
Call-Transfer is workin ok in both phones! It was my mistake! I didn't see a soft-button in the Polycom!
Thanks a lot for your time!
Now, I have to find the way to do Call Pickup Group.
