4000 Series Routers DSP FARM?
patrick.hurley
Level 3
Level 3
Is there a way to create a DSP farm with a cisco 4000 series router?
Manish Gogna
Hi Patrick,
Please check the following link, it covers the dsp related config on 4000 series
http://www.cisco.com/c/en/us/support/docs/routers/4000-series-integrated-services-routers/118792-config-isr-00.html
Manish
I guess my question is that because the 4000 series routers only support 1 DSP slot on the motherboard, what is Cisco's strategy for DSP Farms.   Will the 3925E/3945E be used for that?
Hi Patrick,
Cisco 4000 Series PVDMs are available in two form factors with four supported densities in each form factor:
●   Motherboard PVDMs (PVDM4) for densities up to 256 channels
●   PVDM enhanced services modules (SM-X-PVDM) for densities up to 3080 channels
The details about their support and capacities is listed in the following link
http://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet_c78-728307.html
So, its just not the motherboard PVDM's that are available on the 4000 series.
Manish
