606 from application server, voip,sip
I have happened to test if the call flow is correct since one of my team members done the patch upgrade in the web server.
All I wanted to check is I have to make a call and check if the two way audio is working fine.
Since all are working from home, I have installed bria(soft phone a)my laptop which is my DUT. We would normally make a call like this.. we also have a PRI AND SIP softphone a,w PSTN  Like wise, I placed aca from Bria to all the tollfree numbers I have given with. It was working fine. When I tried to make a call fromefrom sip or pri which is registered in my laptop  to the Bria phone where it is also registered in my laptop, and the call wasn't placed ..upon checking the trace ,I would see that the invite is reaching the application server and the app server in turn contacting my laptop (would see my laptop ip there after APP SERVER) and it tries for multiple invite and straight away AS sending the 606 ( nit acceptable) error to SIP .
When I checking the working where the call has made from sip to Bria ,the invite goes to SBC components and it is reaching the laptop.
Note : The same Bria number registered in one of my friend's laptop and tried calling, all inbound and outbound call is working fine. Then I came to know the isse is with my laptop and couldn't not fine where it would lias with.
Can somebody help me to resolve this issue.
Thanks ,
Kani
TONY SMITH
What call control product are you using, the "application server"?
Yes. It is application server
