6901 config informations
gabiulici
Hii guys,
I have 4 X 6901 and I have to config the Phone when I pick-up the handset the phone to be able to  call a specific NR. They want to restrict those phone internally.
I create e Route Pattern/Partition/CSS but I don't now exactly where to put the NR what the phone will dial automatically when I pick-up the handset .
Any ideas???
kkoeper12
Level 3
Level 3
For PLAR just create a new partition with only 1 thing in it: a translation pattern from nothing to the number you want to dial. Make sure the translation pattern has a CSS that can reach the translated number. Then create a CSS with only that 1 partition in it and assign that CSS to the phone. Easy peasy.
7 Replies 7
Jaime Valencia
There are plenty of references on cisco.com and CSC on how to configure a PLAR, have you reviewed them???
java
if this helps, please rate
I deed the config from this link but not working.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/47601-config-hotdial.html
Is the phone SCCP or SIP?
java
The phone is SCCP. My question is what nr should I put on Line or it doesn't mater???
The phone needs a DN, but it can be anything you want, if your phone is SCCP, the link you mentioned is all you need, if it's not working, go back and review your config is exactly as explained.
java
kkoeper12
Level 3
Level 3
gabiulici
Thanks guys for  help. It work fine but I have a problem. When I pick-up the headset from 6901 the  call go to my 7841 device but they want to make the 7841 to be forward to and external Phone           ( GSM) but is not working  exeple ( 0743536882)
