6901 & SG300 VLAN Auto Detect How To???
chris parkinson
Beginner
Beginner
I have an SG 300, ports configured per below, and some 6901 phones.
My 7942 phones work great with this config, CDP puts them right on the voice VLAN 100 and everything works as it should.
The 6901 just seem to spin their wheels and never get onto VLAN 100.  For the 6901 to work, I have to change the switch port to native VLAN 100.
I've read in the 6901/11 admin guide "Cisco Unified IP Phone 6901 does not support VLANs. " but this is not really a useful statement, as it has no context.
Can/should the 6901 be able to function with the switch config below?  And what are the constraints, if any?
I'd appreciate any pointers.
vlan database
vlan 100
exit
voice vlan id 100
voice vlan state auto-enabled
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 0007eb "Cisco Phone 3"
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
voice vlan oui-table add a8b1d4 "Cisco Phone 2"
hostname SW08L29RE
line console
no autobaud
exit
line console
speed 9600
exit
! Account info removed
clock timezone MST -7
clock source sntp
interface vlan 1
ip address 192.168.1.226 255.255.255.0
no ip address dhcp
interface vlan 100
name Voice
interface fastethernet1
switchport trunk allowed vlan add 100
interface fastethernet2
interface fastethernet3
interface fastethernet4
interface fastethernet5
interface fastethernet6
interface fastethernet7
interface fastethernet8
interface gigabitethernet1
interface gigabitethernet2
exit
macro auto disabled
Manish Gogna
Is the issue seen with phones running firmware 9.3(1)SR1 or higher as well?
Please check the following bug
https://tools.cisco.com/bugsearch/bug/CSCtz55425/?reffering_site=dumpcr
Manish
Manish Gogna
Manish
Manish, thanks, that was just what we needed, we were on 9.2, upgraded to 9.3(1)SR1 and they worked as expected.
Chris
Recognize Your Peers
