08-23-2013 11:37 AM - edited 03-16-2019 07:01 PM
We have a cucm 8.6.2 and have 4-5 phone model connected to our server.
Recently we had some problem with the 6921 phone model, history call unavailable, transfer call doesn't work. The firmware load was 9.3.1 so I've just download the lastest firmware 9.3.3(SR1) and make the upgrade, the history call is available but now the time on the phone is 4 hour later. all other phone got the correct time, only the 6921 who's reboot and upgrade.
How can I correct it.
08-23-2013 12:54 PM
Was it working fine with the old firmware? If it was, then it could be a new bug with the latest release. I would suggest opening a TAC case and have TAC take a look at it.
Posted by WebUser Asad Raza from Cisco Support Community App
08-26-2013 04:22 AM
This is a known bug and first found in 9.3(3), Bug ID CSCuf66550. The bug toolkit says it is fixed in 9.3(3)SR1 and 9.3(3)ES2. Have you tried the other version?
| 6900 series phones do not show correct time | |
| Symptom: 6900 phones are having an issue with showing the correct time. Conditions: Issue occurs only with firmware 9.3.3.2 on CME 8.6. Workaround: Downgrade to 9.1.1.2 | |
BR,
Peter
08-26-2013 05:11 AM
I didn't have access to 9.3(3)ES2 in the download section.
I can try the workaround but it's strange to downgrade by 2 major version, why they don't suggest 9.2.4
08-29-2013 06:48 AM
Hi create a TAC and they ask me to install the lastest devicepack available for my CUCM version. Jobs done, it's working now.
