04-22-2013 08:31 AM - edited 03-16-2019 04:56 PM
Has anyone experienced this issue with the 6921 on-hook clips. We turn the clip around when the phone is wall mounted and it hold the phone in. But it comes out so easily, as soon as you lift the handset out it pulls the clips out!!! we have like 30 - 6921 phones that have done this. I need to know if its possible to get spare 6921 clips, because we need them, anyone have an info on this? Thanks
10-31-2014 08:43 AM
Did you find a vendor for these parts? I'm in need of them too.
01-07-2015 08:35 AM
were you able to find? we have the same issue. students seem to take them off.
01-07-2015 08:38 AM
no, All the vendors I talked with say the phone is too new and not worth the money to fabricate yet. Not enough call for them.
01-07-2015 08:39 AM
we are going to try and glue them in
01-07-2015 09:11 AM
we will try 3D print them and then glue.
some of ours are missing
01-07-2015 09:13 AM
Hello Fellas, we where unsuccessfull in getting these clips. I think we are also opting to glue them in.
09-23-2016 11:21 AM
We have a couple hundred of the 6921 model. I have searched high and low. Wall phones are critical for us, so when the clip goes, we have to replace the entire phone--not very economical.
I have resorted to gluing them--learned my lesson the hard way.
