6941/6945 Multiple calls per line - Flash only on 2nd call
Steve Boyd
With either of these phones and the multiple calls per line feature, I'm only able to get the 2nd call to alert with a flash and not and audible ring.  Is this working as expected, or should a ring be possible when the phone is active?   I've checked all the ring settings for the line and they look correct.
This is on UCM 9.1.1.20000-5 and 6945 SCCP firmware  9-3-1-3
Thanks.
Hythim Ali El Hadad
Frequent Contributor
Hi Stephen,
You will find it in call manager service parameter
Ring Setting of Busy Station Policy
then
Choose what you need to apply
Haitham
Recognize Your Peers
