Walkthrough Wednesdays
181
GRANT3779
Frequent Contributor
6941 Phone - CME 4.2
Looking at the supported hardware for CME 4.0, the 6941 is not listed.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme42spc.htm
Does this mean it is impossible to get the phone working with CME 4.0? Or could I download firmware files for a different version and it woud work?
Don't want to try it just incase it goes wrong
3 REPLIES 3
Tagir Temirgaliyev
you can upgrade router ios
Hi There, is this the only option?
Jaime Valencia
Hall of Fame Cisco Employee
Yes, your CME code does not contain how to use that phone. You need a version which supports it
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Content for Community-Ad
Spotlight Awards 2021
